查看: 4704|回复: 4
[原创] JSSC-2011-06
发表于 2011-5-24 15:10:39 | 显示全部楼层 |阅读模式
Analysis and Design of Small-Signal Polar Transmitters for Cellular Applications
Analysis and Design of D-Band Injection-Locked Frequency Dividers
A Wideband Millimeter-Wave Frequency Synthesis Architecture Using Multi-Order Harmonic-Synthesis and Variable n-Push Frequency Multiplication
A Supply-Rail-Coupled eTextiles Transceiver for Body-Area Networks
A 10.2 Mbps Pulse Harmonic Modulation Based Transceiver for Implantable Medical Devices
A Frequency Synthesizer With Optimally Coupled QVCO and Harmonic-Rejection SSBmixer for Multi-Standard Wireless Receiver
Low-Power CMOS Equalizer Design for 20-Gb/s Systems
7.4 Gb/s 6.8 mW Source Synchronous Receiver in 65 nm CMOS
A Charge-Domain Auto- and Cross-Correlation Based Data Synchronization Scheme With Power- and Area-Efficient PLL for Impulse Radio UWB Receiver
A 10-bit, 40-MS/s, 1.21 mW Pipelined SAR ADC Using Single-Ended 1.5-bit/cycle Conversion Technique
A 14 bit 200 MS/s DACWith SFDR 78 dBc, IM3 83 dBc and NSD 163 dBm/Hz Across the Whole Nyquist Band Enabled by Dynamic-Mismatch Mapping
A CMOS 4.35-mW +22-dBm IIP3 Continuously Tunable Channel Select Filter for WLAN/WiMAX Receivers
AMicropower Low-Noise Neural Recording Front-End Circuit for Epileptic Seizure Detection
A 60 pWg C ContinuousWavelet Transform Circuit for Portable EEG Systems
An 847–955 Mb/s 342–397 mW Dual-Path Fully-Overlapped QC-LDPC Decoder for WiMAX System in 0.13 m CMOS
A 100 pJ/bit, (32,8) CMOS Analog Low-Density Parity-Check Decoder Based on Margin Propagation
A 3.6 s Latency Asynchronous Frame-Free Event-Driven Dynamic-Vision-Sensor
CMOS Silicon Physical Unclonable Functions Based on Intrinsic Process Variability
A 10-MHz Green-Mode Automatic Reconfigurable Switching Converter for DVS-Enabled VLSI Systems
1.8 V Low-Transient-Energy Adaptive Program-Voltage Generator Based on Boost Converter for 3D-Integrated NAND Flash SSD
An Energy Efficient Generator With Fast Ramp-Up Time for Mobile DRAM
A 3T Gain Cell Embedded DRAM Utilizing Preferential Boosting for High Density and Low Power On-Die Caches
JSSC-06-1.rar
14.24 MB, 下载次数: 145 , 下载积分: 资产 -5 信元, 下载支出 5 信元
JSSC-06-2.rar
13.43 MB, 下载次数: 133 , 下载积分: 资产 -5 信元, 下载支出 5 信元
JSSC-06-3.rar
13.3 MB, 下载次数: 130 , 下载积分: 资产 -5 信元, 下载支出 5 信元
JSSC-06-4.rar
12.57 MB, 下载次数: 125 , 下载积分: 资产 -5 信元, 下载支出 5 信元
发表于 2011-5-24 16:27:55 | 显示全部楼层
回复 1# ansarwang
    多谢分享。
发表于 2011-5-31 18:37:32 | 显示全部楼层
非常感谢
发表于 2011-6-1 09:29:54 | 显示全部楼层
very good , thank you so much.
发表于 2018-4-27 09:51:20 | 显示全部楼层
非常感謝~~~
GMT+8, 2025-12-21 07:43 , Processed in 0.019844 second(s), 6 queries , Gzip On, Redis On.
