查看: 2463|回复: 2
[原创] 自创printk打印函数。有改进地方请指教。
发表于 2011-5-17 16:47:30 | 显示全部楼层 |阅读模式
void printk(int a, char *fmt, ...)
int i =0;
int Ret = 0;
char fomt[200];
char Fomtt[200];
int *tmp = &a;
tmp = tmp + 2;
for (i = 0; i < 200; i++)
  fomt[i] = fmt[i];
  if (fomt[i] == '\n')
   i = 200;
   Fomtt[0] = Ret;
  if (fomt[i] == '%')
   Ret++;
  if ((fomt[i] == 'd') & (fomt[i-1] == '%'))
   Fomtt[Ret] = 'd';
  if ((fomt[i] == 's') & (fomt[i-1] == '%'))
   Fomtt[Ret] = 's';
  if ((fomt[i] == 'c') & (fomt[i-1] == '%'))
   Fomtt[Ret] = 'c';
  if ((fomt[i] == 'x') & (fomt[i-1] == '%'))
   Fomtt[Ret] = 'x';
for (i = 0;i < Ret; i++)
   if (Fomtt[i+1] == 's')
    if (a == 1)
     printf("ERROR:%s \n", *tmp);
    if (a == 2)
     printf("INFO:%s \n", *tmp);
   if (Fomtt[i+1] == 'd')
    if (a == 1)
     printf("ERROR:%d \n", *tmp);
    if (a == 2)
     printf("INFO:%d \n", *tmp);
   if (Fomtt[i+1] == 'x')
    if (a == 1)
     printf("ERROR:%x \n", *tmp);
    if (a == 2)
     printf("INFO:%x \n", *tmp);
   if (Fomtt[i+1] == 'c')
    if (a == 1)
     printf("ERROR:%c \n", *tmp);
    if (a == 2)
     printf("INFO:%c \n", *tmp);
   tmp++;
 楼主| 发表于 2011-5-18 16:31:12 | 显示全部楼层
int Othe2Des(const char *Str, const int Othe)
        unsigned int i = 0;
        unsigned int b = 0;
        unsigned int l = 0;
        unsigned int j = 0;
        unsigned int x = 0;
        unsigned int s[20] = {0};
        unsigned int v[20] = {0};
        if ((Str == 0ul) && (Othe == 0))
                return 0;
        j = Othe;
        while(1)
                if ((Str[i] < 58) && (Str[i] > 47))
                        s[i] = (Str[i] - 48);
                if ((Str[i] < 71) && (Str[i] > 64))
                        s[i] = (Str[i] - 55);
                if (Str[i] == 0)
                        break;
                i++;
        for (i-- ; i > 0; i--)
                while (1)
                        l++;
                        if (l == i)
                                l = 0;
                                break;
                        j *= Othe;
                if (i == 0)
                        break;
                b += s[x] * j;
                j = Othe;
                x++;
        return b+2;
char *Dec2Othe(const long int Dec, const int Othe)
        long int temp = 0;
        int bl = 0;
        int i = 0;
        int Othes[20] = {0};
        char ReturnStr[20] = {0};
        temp = Dec;
        while (1)
                bl = temp%Othe;
                Othes[i] = bl;
                if (temp == 0)
                        break;
                i++;
                temp = temp/Othe;
        bl = 0;
        for (i--;i >= 0;i--)
                if (Othes[i] == 10)
                        ReturnStr[bl] = 'A'        ;
                if (Othes[i] == 11)
                        ReturnStr[bl] = 'B'        ;
                if (Othes[i] == 12)
                        ReturnStr[bl] = 'C'        ;
                if (Othes[i] == 13)
                        ReturnStr[bl] = 'D'        ;
                if (Othes[i] == 14)
                        ReturnStr[bl] = 'E'        ;
                if (Othes[i] == 15)
                        ReturnStr[bl] = 'F'        ;
                if ((Othes[i] < 10) && (Othes[i] >= 0))
                        ReturnStr[bl] = (char)(Othes[i] + 48);
                bl++;
        return ReturnStr;
 楼主| 发表于 2011-5-18 17:56:49 | 显示全部楼层
int StrLen_k(char *str)
        int i = 0;
        char *b = 0ul;
        if (str == 0ul)
                return ~0;
        b = str;
        while (1)
                if (b[i] == 0)
                        break;
                i++;
        return i;
int StrCpy_k(char *Op, const char *d)
        int i = 0;
        if ((Op == 0ul) && (d == 0ul))
                return ~0;
        while (1)
                Op[i] = d[i];
                if (d[i] == 0)
                        break;
                i++;
        return 1;
char *Des2Ch(const unsigned int Des)
        int Ds = 0;
        int i = 0;
        int n = 0;
        unsigned int dd = 0;
        char zstr[20] = {0};
        char bn[20] = {0};
        dd = Des;
        while (1)
                Ds = dd%10;
                if (Ds == 0)
                        break;
                dd = dd/10;
                zstr[i] = (char)(Ds + 48);
                i++;
        for (i--;i>=0;i--)
                bn[n] = zstr[i];
                n++;
        return bn;
        unsigned int i = 0;
        unsigned int b = 0;
        unsigned int l = 0;
        unsigned int j = 0;
        unsigned int x = 0;
                return 0;
        j = Othe;
        while(1)
                if (Str[i] == 0)
                        break;
                i++;
                while (1)
                        l++;
                        if (l == i)
                                l = 0;
                                break;
                        j *= Othe;
                if (i == 0)
                        break;
                b += s[x] * j;
                j = Othe;
                x++;
        return b+2;
        long int temp = 0;
        int bl = 0;
        int i = 0;
        temp = Dec;
        while (1)
                bl = temp%Othe;
                Othes[i] = bl;
                if (temp == 0)
                        break;
                i++;
                temp = temp/Othe;
        bl = 0;
                if (Othes[i] == 10)
                if (Othes[i] == 11)
                if (Othes[i] == 12)
                if (Othes[i] == 13)
                if (Othes[i] == 14)
                if (Othes[i] == 15)
                bl++;
        return ReturnStr;
void printk(char *fmt, ...)
        int i =0;
        int f = 0;
        int Len = 0;
        int m = 0;
        char fomt[200] = {0};
        char *nesr = 0ul;
        int *tmp = &fmt;
        tmp++;
                fmt[i];
                if (fmt[i] == '\n')
                {i = 200;}
                if (fmt[i] == '%')
                    i++;
                        switch(fmt[i])
                                case 'd':
                                                StrCpy_k(nesr,Des2Ch(Othe2Des(*tmp, 16)));
                                                Len = StrLen_k(nesr);
                                                for (m=0;m<Len;m++)
                                                        fomt[f] = nesr[m];
                                                        f++;
                                case 'x':
                                        {*tmp;}
                                case 's':
                                        {*tmp;}
                                case 'c':
                                        {*tmp;}
                                tmp++;
                else
                        fomt[f] = fmt[i];
                        f++;
GMT+8, 2025-9-14 08:16 , Processed in 0.016734 second(s), 7 queries , Gzip On, Redis On.
