查看: 7103|回复: 1
[原创] Quartus中利用FFT的IP核无法仿真出数据波形
发表于 2011-4-23 16:01:18 | 显示全部楼层 |阅读模式
在Quartus中调用FFT的IP核,用的器件是cyclone 3,手册上说3代得ip核是preliminary的,时序仿真有点问题,不知道这是怎么回事。自己用的是streaming的结构,ready,valid,sop,eop也都加了,但是就是没有fft数据出来。仿真时间也足够长,采用64点,512点都试过了,时序仿真的时候报warning:
Warning: Can't display state machine states -- register holding state machine bit "|fft_test|FFT:inst|asj_fft_sglstream_fft_72:asj_fft_sglstream_fft_72_inst|fft_s1_cur.last_input" was synthesized away
Warning: Can't display state machine states -- register holding state machine bit "|fft_test|FFT:inst|asj_fft_sglstream_fft_72:asj_fft_sglstream_fft_72_inst|fft_s1_cur.check_dav" was synthesized away
Warning: Can't display state machine states -- register holding state machine bit "|fft_test|FFT:inst|asj_fft_sglstream_fft_72:asj_fft_sglstream_fft_72_inst|fft_s1_cur.write_input" was synthesized away
Warning: Can't display state machine states -- register holding state machine bit "|fft_test|FFT:inst|asj_fft_sglstream_fft_72:asj_fft_sglstream_fft_72_inst|fft_s1_cur.wait_for_input" was synthesized away
还有好几个这样的warning,不知道大家遇到没有,求高人解答
发表于 2011-5-15 13:34:43 | 显示全部楼层
楼主问题解决了吗?我也在弄这个最近?498805324
GMT+8, 2025-11-20 19:30 , Processed in 0.020478 second(s), 7 queries , Gzip On, Redis On.
