查看: 3284|回复: 6
[招聘] 急啊!上海著名IC公司急招前后端职位!
发表于 2011-4-20 17:03:15 | 显示全部楼层 |阅读模式
著名外资design service公司(上海)急招5-8年数字后端一名担任PR leader
联系顾问E-mail:digital1@kthr.com,MSN:conniewang1987228@hotmail.com
Depending on experience, key responsibilities will involve some of the following:
·   Development and optimisation of high performance and low power Soc physical implementation methodology
·   Working with European engineers to do block level and full chip floor planning, timing and power analysis, and P&R
·   Design consulting in customer's offices on physical implementation tasks
·   Interfacing with foundry and IP providers on IP imports and test definition.
Desired Skills and Experience:
Some experience in physical design engineering coupled with a good degree and a desire to be at the leading edge of new technologies.
The successful applicants will have exposure to at least some of the following areas:
·    Digital Soc chip design and implementation
·    Design automation and analysis using scripting languages, particular Tcl and Perl
·    Design Flows and the EDA tools, in particular tools from Magma, Mentor and Synopsys. Experience with tools from Apache and Azuro would be an advantage
·    Sign-off methodology and EDA tools for STA, Noise, Power, etc.
·    Structured design styles involving placed gates
·    ATPG tools and methodologies.
著名台资design service公司急寻前端project manager
Job Description:
1.Lead front-end design team and coach junior members on design knowledge and way of working. Ensuring the design process meets budget, schedule and project plan goals
2.Work with customer to define detail SoC specification
3.Work with the Architect to design the system bus architecture of SoC, Implement the system bus
4..IP verification and integration
5.System level integration and verification
6.Back-end design related support
Required Skills:
1.MSEE Degree or equivalent
2.Knowledgeable in ASIC design methodology
3.Minimum 5 year experience in the hands-on IC Design
4.Be familiar with ARM process and AHB, AXI protocol.
5.Familiarity of FPGA prototyping
以上职位来源于“胡说IC”论坛
 楼主| 发表于 2011-4-20 17:04:32 | 显示全部楼层
希望合适的工程师和我们联系,如果有朋友需要麻烦帮我们推荐,谢谢!:)
 楼主| 发表于 2011-4-21 15:11:18 | 显示全部楼层
急呀急呀,有合适的帮忙推荐下哦
发表于 2011-4-24 15:24:16 | 显示全部楼层
kan kan
发表于 2011-4-24 15:36:07 | 显示全部楼层
reference
发表于 2011-4-24 15:56:49 | 显示全部楼层
后面那个应该是创意电子招的吧
发表于 2011-5-7 18:20:40 | 显示全部楼层
路过!!
GMT+8, 2025-12-20 07:22 , Processed in 0.020709 second(s), 6 queries , Gzip On, Redis On.
