查看: 7828|回复: 23
[原创] 一只新手写了一些简单源码,给下quartus6.0-10.1都可以用的破解文件
发表于 2011-4-15 18:21:44 | 显示全部楼层 |阅读模式
不解释,直接源码
36位加法分频器 duty 1:35
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity adder36 is
    port (clk,rst,en : in std_logic;
                  cq : out std_logic_vector(5 downto 0);
                cout : out std_logic );
end adder36;
architecture sun of adder36 is
begin
   process (clk,rst,en)
     variable cqi :std_logic_vector (5 downto 0);
   begin
     if rst = '1'  then cqi:=(others =>'0');
     elsif clk'event and clk='1'  then
       if en='1'  then
         if cqi<35  then cqi:=cqi+1;
         else cqi:= (others =>'0');
         end if;
       end if;
     end if;         -- if cqi>="100011" then cout<=not cout;
     if cqi=35  then cout <='1';
     else cout <='0';
     end if;
     cq<=cqi;
   end process;
   end sun;
三八译码器  高电平输出
library ieee;
entity ymq38 is
  port (din  :  in std_logic_vector  (2 downto 0);
        dout : out std_logic_vector (7 downto 0)  );
end;
architecture behav of ymq38 is
  begin
  process (din)
  begin
    if    (din="001")  then dout <="00000001";
    elsif (din="010")  then dout <="00000010";
    elsif (din="011")  then dout <="00000100";
    elsif (din="100")  then dout <="00001000";
    elsif (din="101")  then dout <="00010000";
    elsif (din="110")  then dout <="00100000";
    elsif (din="111")  then dout <="01000000";
                       else dout <="00000000";
    end if;
  end process;
end;
七人表决器 四人以上可以输出P,否则E    可以显示结果
library ieee;
entity qrbjq is
port (
        set: in std_logic ;                       ----控制按键
        xin: in std_logic_vector ( 6 downto 0 );  ----按键输入表决
        sel: out std_logic;                       ----控制指示灯
        xout,xout0,xout1: out std_logic_vector ( 6 downto 0 )
      );    ----xout显示结果,xout0显示否决的人数,xout1显示赞成的人数
end entity ;
architecture bev of qrbjq is
begin
   process ( xin ,set)
   variable j: integer :=0;
   begin
      j:=0;
   for i in 0 to 6 loop   ------统计同意的个数
    if xin(i)='1' then
      j:=j+1;
    end if;
   end loop;
if j>3 then           ---判决是否表决通过并输出结果
xout<="0001100";      ---数码管显示P
else xout<="0000110"; ---数码管显示E
end if;
if set='1' then       ---是否显示表决比例
   sel<='1';          ---显示指示灯亮并且译码输出同意与不同意的数目
case j is            ---显示赞成的人数
    when 0 =>xout1<="1000000";
    when 1 =>xout1<="1111001";
    when 2 =>xout1<="0100100";
    when 3 =>xout1<="0110000";
    when 4 =>xout1<="0011001";
    when 5 =>xout1<="0010010";
    when 6 =>xout1<="0000010";
    when 7 =>xout1<="1111000";
    when others =>xout1<="XXXXXXX";
   end case;
case j is           ---显示不赞成的人数
    when 7 =>xout0<="1000000";
    when 6 =>xout0<="1111001";
    when 5 =>xout0<="0100100";
    when 4 =>xout0<="0110000";
    when 3 =>xout0<="0011001";
    when 2 =>xout0<="0010010";
    when 1 =>xout0<="0000010";
    when 0 =>xout0<="1111000";
    when others =>xout0<="XXXXXXX";
   end case;
else                ---不显示表决比例
   sel<='0';
   xout0<="1111111";---不显示数字
   xout1<="1111111";
end if;
   end process;
end architecture bev;
四七译码器
library ieee;
entity disp4_7 is
port(d: in std_logic_vector(3 downto 0);
     y: out std_logic_vector(6 downto 0));
end disp4_7;
architecture sun of disp4_7 is
begin
process(d)
Begin
case d is
  when "0000"=>y<="1111110";
  when "0001"=>y<="0110000";
  when "0010"=>y<="1101101";
  when "0011"=>y<="1111001";
  when "0100"=>y<="0110011";
  when "0101"=>y<="1011011";
  when "0110"=>y<="1011111";
  when "0111"=>y<="1110010";
  when "1000"=>y<="1111111";
  when "1001"=>y<="1111011";
  when others=>y<="1000111";
end case;
end process;
end sun;
32位加法分频器 duty 50% (改一个参数就可以改占空比)
library ieee;
entity adder32 is
end adder32;
architecture sun of adder32 is
        signal cout1 :std_logic;
   begin
   process (clk,rst,en,cout1)
   begin
       if en='1'  then
         if cqi<32  then cqi:=cqi+1;
         end if;
       end if;
     if cqi=0 then cout1<='0';
     elsif (cqi=16) and (clk'event and clk='1') then cout1<=not cout1;
     end if;
     cq<=cqi;
     cout<=cout1;
   end process;
   end sun;
八位数据0的个数
library ieee;
entity zeronum8 is
port (  xin : in std_logic_vector ( 7 downto 0 );
            set :  in std_logic;
          xout : out integer range 7 downto 0
end entity ;
architecture bev of zeronum8 is
begin
  process ( xin ,set)
  begin
  if set='1' then
      j:=0;
    for i in 0 to 7 loop
    if xin(i)='0' then    --0 numbers
      j:=j+1;
    end if;
    end loop;
  end if;
xout<=j;
  end process;
这里是破解文件,6.0-10.1都可以,里面有详细介绍
Quartus II_6.0-10.1CRACK未改版.rar (749.89 KB , 下载次数: 193 )
 楼主| 发表于 2011-4-15 18:26:15 | 显示全部楼层
考研期间有时间就会再来用quartus II编变
 楼主| 发表于 2011-4-16 18:11:43 | 显示全部楼层
没人想要我的crack啊
发表于 2011-4-16 21:44:51 | 显示全部楼层
Windows的还是Linux的?
发表于 2011-4-18 10:04:13 | 显示全部楼层
没有dsp builder
发表于 2011-4-18 10:07:09 | 显示全部楼层
真的吗,我下来试试看
发表于 2011-5-6 15:21:03 | 显示全部楼层
里面有dsp builder的吗?
发表于 2011-5-6 15:24:14 | 显示全部楼层
看到了我当年写代码的影子。
发表于 2011-5-14 07:39:32 | 显示全部楼层
真的吗,我下来试试看
发表于 2011-5-19 15:40:33 | 显示全部楼层
Cyclone III & Cyclone IV,只能合成出 *.sof, 不能合成出 *.pof.
GMT+8, 2025-12-27 08:37 , Processed in 0.021301 second(s), 6 queries , Gzip On, Redis On.
