查看: 18025|回复: 60
[原创] MIT(2010)45nm direct battery DC-DC converter for mobile
发表于 2011-4-5 11:38:36 | 显示全部楼层 |阅读模式
Title: 45nm direct battery DC-DC converter for mobile
Author: Bandyopadhyay, Saurav
Other Contributors: Massachusetts Institute of Technology. Dept. of Electrical Engineering and Computer Science.
Advisor: Anantha P. Chandrakasan.
Department: Massachusetts Institute of Technology. Dept. of Electrical Engineering and Computer Science.
Publisher: Massachusetts Institute of Technology
Issue Date: 2010
Abstract: Portable devices use Lithium-ion batteries as the energy source due to their high energy density, long cycle life and low memory effects. With the aggressive downscaling of CMOS, it is becoming increasingly difficult to efficiently interface the low voltage, low power digital baseband and DSP of the mobile phone with the battery which maybe at voltages as high as 4.2V. This is efficiently done by a DC-DC converter which is a separate IC designed on an older generation process capable of handling high voltages. However, this requires an extra IC, thereby increasing the overall system cost. Here, a buck converter is demonstrated on a standard 45nm digital CMOS process which can be integrated with the 45nm digital core on the same die. This converter is capable of handling high battery voltages (2.8V to 4.2V) and delivers a regulated low voltage (0.5V to 1.1V) to the digital core. The converter can supply 20[mu]A to 100mA of load current. The peak efficiency of the converter is 87% for 73mW output at 4.2V supply and for the ultra low power levels, efficiency of 75% is obtained for a 20[mu]W load at 3V. Both pulse width modulation (PWM) and pulse frequency modulation (PFM) modes of control are used. A new digital pulse width modulator (DPWM) architecture is presented which provides 75% area savings over the conventional delay line and counter based architecture with comparable power consumption. The buck converter also requires Switched Capacitor (SC) DC-DC Converters to generate stacking regulators and regulator for the control circuitry. On the whole, the complete system integrates the Power Management Unit with the core for a single chip radio in 45nm.
Description:
Thesis (S.M.)--Massachusetts Institute of Technology, Dept. of Electrical Engineering and Computer Science, 2010.
Includes bibliographical references (p. 65-66).
45nm direct battery DC-DC converter for mobile.pdf
6.69 MB, 下载次数: 590 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2011-4-5 11:42:26 | 显示全部楼层
nice, looking forward to read it, thx
发表于 2011-4-5 18:47:32 | 显示全部楼层
顶下来看看
发表于 2011-4-5 19:16:43 | 显示全部楼层
THX FOR SHARING
发表于 2011-4-5 23:15:12 | 显示全部楼层
多谢楼主分享,这个材料很有意思
发表于 2011-4-6 07:36:46 | 显示全部楼层
dddddddddddddd
发表于 2011-4-6 09:07:36 | 显示全部楼层
发表于 2011-4-6 09:45:01 | 显示全部楼层
wolskfkfkfkkfkfk
发表于 2011-4-6 10:07:26 | 显示全部楼层
thanks!!!
发表于 2011-4-6 11:17:16 | 显示全部楼层
GMT+8, 2025-12-29 15:31 , Processed in 0.027734 second(s), 6 queries , Gzip On, Redis On.
