查看: 4602|回复: 9
[求助] 求安装过cadence5141的强人,解决疑难问题!!!!
发表于 2011-4-2 16:03:48 | 显示全部楼层 |阅读模式
我在rhel4中安装cadence 安装步骤都是从网上找的,但是运行终端之后总显示下面的东西。无解中.....
declare -x CDS_LIC_FILE="/share/license/license.dat"
declare -x COLORTERM="gnome-terminal"
declare -x DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-FMN29FhVaM"
declare -x DESKTOP_SESSION="default"
declare -x DESKTOP_STARTUP_ID=""
declare -x DISPLAY=":0.0"
declare -x GDMSESSION="default"
declare -x GNOME_DESKTOP_SESSION_ID="Default"
declare -x GNOME_KEYRING_SOCKET="/tmp/keyring-TeDIA7/socket"
declare -x GTK_RC_FILES="/etc/gtk/gtkrc:/root/.gtkrc-1.2-gnome2"
declare -x G_BROKEN_FILENAMES="1"
declare -x HISTSIZE="1000"
declare -x HOME="/root"
declare -x HOSTNAME="localhost.localdomain"
declare -x INPUTRC="/etc/inputrc"
declare -x LANG="en_US.UTF-8"
declare -x LD_ASSUME_KERNEL="2.4.0"
declare -x LESSOPEN="|/usr/bin/lesspipe.sh %s"
declare -x LOGNAME="root"
declare -x LS_COLORS="no=00:fi=00:di=00;34:ln=00;36:pi=40;33:so=00;35:bd=40;33;01:cd=40;33;01r=01;05;37;41:mi=01;05;37;41:ex=00;32:*.cmd=00;32:*.exe=00;32:*.com=00;32:*.btm=00;32:*.bat=00;32:*.sh=00;32:*.csh=00;32:*.tar=00;31:*.tgz=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.bz=00;31:*.tz=00;31:*.rpm=00;31:*.cpio=00;31:*.jpg=00;35:*.gif=00;35:*.bmp=00;35:*.xbm=00;35:*.xpm=00;35:*.png=00;35:*.tif=00;35:"
declare -x MAIL="/var/spool/mail/root"
declare -x OLDPWD
declare -x PATH="/cadence/tools/bin:/cadence/tools/dfII/bin:/cadence/tools/dfII//bin:/cadence/tools/spectre/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/bin"
declare -x PWD="/root"
declare -x SESSION_MANAGER="local/localhost.localdomain:/tmp/.ICE-unix/5163"
declare -x SHELL="/bin/bash"
declare -x SHLVL="2"
declare -x SSH_AGENT_PID="5188"
declare -x SSH_ASKPASS="/usr/libexec/openssh/gnome-ssh-askpass"
declare -x SSH_AUTH_SOCK="/tmp/ssh-mkEdBL5187/agent.5187"
declare -x TERM="xterm"
declare -x USER="root"
declare -x WINDOWID="35651663"
declare -x XAUTHORITY="/root/.Xauthority"
而且运行icfb& 启动cadence终止,图像如下
如果有强人遇到过类似的问题,请求解决。如果有成功安装过cadence的 请说一下安装步骤,感谢!!!!!!!!!!!!!
发表于 2011-4-2 16:07:11 | 显示全部楼层
估计你在.bashrc文件中“PATH="前面的”export“后面用了回车 而不是空格
 楼主| 发表于 2011-4-2 17:13:23 | 显示全部楼层
回复 2# muyu0786
非常感谢,的确是你说的问题!!!!!
不够启动cadence的时候还是出现这个
 楼主| 发表于 2011-4-2 17:13:26 | 显示全部楼层
回复 2# muyu0786
非常感谢,的确是你说的问题!!!!!
发表于 2011-4-2 21:45:39 | 显示全部楼层
图片上不是好了吗?怎么还出现呢?
发表于 2011-4-3 12:14:31 | 显示全部楼层
LZ想说出现什么? 这个就是正常启动了啊?不会没用过吧?
发表于 2011-4-4 21:41:40 | 显示全部楼层
我的启动照片是这样的,并且窗口内没法使用,大家遇到过这样的情况吗?怎么解决的?
多谢指点
发表于 2011-4-4 22:22:33 | 显示全部楼层
没有错误信息吗?
这个没遇到过
不过发现你是用root帐户登录使用的,不建议这样
发表于 2013-7-3 07:15:55 | 显示全部楼层
启动时好像不能用窗口吧
发表于 2013-7-3 08:53:24 | 显示全部楼层
不懂顶一下。。。。。。。。
GMT+8, 2025-12-23 22:31 , Processed in 0.027297 second(s), 6 queries , Gzip On, Redis On.
