查看: 3147|回复: 4
请教一个问题
发表于 2006-10-19 13:52:27 | 显示全部楼层 |阅读模式
我在运行这个程序的时候
module binaryToESeg(eSeg,A,B,C,D);
output  eSeg;
input   A,B,C,D;
wire  eSeg,p1,p2,p3,p4;
wire   A,B,C,D;
nand #1
g1(p1,C,~D),
g2(p2,A,B),
g3(p3,~B,~D),
g4(p4,A,C),
g5(eSeg,p1,p2,p3,p4);
endmodule
出现这样的错误
Error: Current license file does not support the EP1S10B672C6 device
请问在选择器件时应该注意些什么呢?
 楼主| 发表于 2006-10-19 13:58:15 | 显示全部楼层
Warning: FLEXlm software error: Invalid (inconsistent) license key  The license-key and data for the feature do not match.  This usually happens when a license file has been altered Feature:       quartus License path:  D:\altera\license.dat FLEXlm error:  -8,523 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com".
还有这个警告
发表于 2006-10-21 15:01:34 | 显示全部楼层
code好好熟啊,是不是那本绿色的verilog书上的
发表于 2006-10-21 15:25:26 | 显示全部楼层
license文件出问题了,或者你没有启动license文件。
发表于 2007-10-10 17:09:10 | 显示全部楼层
请教windfly, 怎么启动 license文件 ?
GMT+8, 2025-12-26 02:50 , Processed in 0.025211 second(s), 6 queries , Gzip On, Redis On.
