查看: 5007|回复: 3
[求助] 求高手指点
发表于 2011-3-7 18:54:06 | 显示全部楼层 |阅读模式
各位好,最近在用edk,刚上手碰到了下面这个问题不知道怎么解决
我是在建好硬件电路之后打开sdk,加入了相关的c文件之后链接文件也产生成功了,
但是运行的时候就报错,错误如下:
Failed to run ELF executable on Target. XMD couldn't connect to remote target. Error::ambiguous command name "x": xadd_comp xadd_hw_hdl_srcfile xadd_hw_ipinst xadd_hw_ipinst_busif xadd_hw_ipinst_parameter xadd_hw_ipinst_port xadd_hw_subproperty xadd_hw_toplevel_port xbreakpoint xchan_close xchan_configure xchan_exists xchan_open xchan_read xchan_write xcheck_constant_signal xcheck_virtex2_device xcheck_virtex4_device xcheck_virtex_device xconnect xcontinue xconvert_binary_to_hex xconvert_num_to_binary xcycle_step xdata_verify xdebugconfig xdel_hw_ipinst xdel_hw_ipinst_busif xdel_hw_ipinst_parameter xdel_hw_ipinst_port xdel_hw_subproperty xdel_hw_toplevel_port xdisassemble xdisconnect xdownload xelf_verify xforce_use_fsl_dow xformat_addr_string xformat_address_string xfsls xgdbclose xgdbserver xget_addr_values_list_for_ipinst xget_addrparam_busif xget_bus_slave_addrpairs xget_connected_busifs_handle xget_connected_p2p_busif_handle xget_connected_ports_handle xget_handle xget_hw_bus_slave_addrpairs xget_hw_busif_handle xget_hw_busif_value xget_hw_busifs_by_subproperty xget_hw_connected_busifs_handle xget_hw_connected_ports_handle xget_hw_ioif_handle xget_hw_ioif_value xget_hw_ipinst_handle xget_hw_mpd_handle xget_hw_name xget_hw_option_handle xget_hw_option_value xget_hw_parameter_handle xget_hw_parameter_value xget_hw_parent_handle xget_hw_port_connectors_list xget_hw_port_handle xget_hw_port_value xget_hw_proc_slave_periphs xget_hw_proj_setting xget_hw_subproperty_handle xget_hw_subproperty_value xget_hw_value xget_ipinst_handle_list_for_iptype xget_mhs_dir xget_name xget_ncf_dir xget_ncf_loc_info xget_port_by_subtype xget_port_type xget_proc_inst_type_list xget_proc_slave_periphs xget_swbld xget_swver xget_swverandbld xget_value xhelp xistep xlist xload xload_hw_library xload_library xload_sysfile xmdmuart_exists xprofile xremove xreset xrmem xrreg xrun xrut xsilentmode xstate xstats xstep xstop xstuffs xtargets xtrace xtracestart xtracestatus xtracestop xverbose xverify xvpconnect xvpio xwatch xwmem xwreg xxxhelp
不知道该怎么解决,无从下手啊
发表于 2011-3-8 09:23:43 | 显示全部楼层
你这个问题有人回答才怪呢,谁有那闲工夫给你看啊
发表于 2011-3-8 14:09:08 | 显示全部楼层
自己耐下心再找找错误!!
发表于 2011-3-8 21:18:15 | 显示全部楼层
问题在这里
”Error::ambiguous command name "x": “
这个提示可以参考一下,命令错了,你只给了个X,系统哪知道X是哪个命令啊,所以后面提示了一大堆以X开头的命令。
如果我这个解释也不对的话,建议你多看看报错的log吧,分析一下应该会有收获的。
这一大段会让人看的有点莫名其妙。
GMT+8, 2025-12-24 21:11 , Processed in 0.017709 second(s), 7 queries , Gzip On, Redis On.
