查看: 13140|回复: 6
[求助] PLL不能后仿问题,急啊
发表于 2011-2-23 19:22:20 | 显示全部楼层 |阅读模式
初始化VCO的控制电压为0V,前仿真可以正确运行,但是后仿一直卡在数据出来之前那个状态,不能继续往下进行;但是我取消控制线上的电压初始化后,却可以正确的往下进行!
请问这是怎么一回事啊,等了好久都没有仿真数据出来!只能不初始化了么?
刚刚看了下,就是卡在这里:
Trying homotopy = gmin for nodests;
Trying homotopy = source for  nodests;
Trying homotopy = dptram for nodests;
再往下就不能动了!!!!!
发表于 2011-2-24 13:23:51 | 显示全部楼层
你把初始电压改变下呢?
你后仿真网表是不是太大了?
 楼主| 发表于 2011-2-24 13:33:00 | 显示全部楼层
回复 4# helianalog
    是啊,网表很大,大概十几M的样子,寄生参数很多啊。昨晚上跑了一晚上,最后出现了ERROR:
Trying `homotopy = gmin' for nodesets.
Trying `homotopy = source' for nodesets.
Trying `homotopy = dptran' for nodesets.
Trying `homotopy = ptran' for nodesets.
Trying `homotopy = arclength' for nodesets.
Error found by spectre during DC solution estimation, during IC analysis,
        during transient analysis `tran'.
    There were 7 attempts to find the DC solution. In 1 of those attempts, a
        signal exceeded the blowup limit of it's quantity. The last signal that
        failed is V(I0.I4|I3|NM3:int_s) = 1.60081 GV, for which the quantity is
        `V' and the blowup limit is (1 GV). It is possible that the circuit has
        no DC solution. If you really want signals this large, set the `blowup'
        parameter of this quantity to a larger value.
Trying `homotopy = gmin' for initial conditions.
Trying `homotopy = source' for initial conditions.
Trying `homotopy = dptran' for initial conditions.
Trying `homotopy = ptran' for initial conditions.
Trying `homotopy = arclength' for initial conditions.
Error found by spectre during IC analysis, during transient analysis `tran'.
    No DC solution found (no convergence).
发表于 2011-2-24 13:35:33 | 显示全部楼层
你抽取网表的时候是怎么选的?RC都抽吗?还是只抽C?
如果RC都抽的话,最小的R和C给了多少
 楼主| 发表于 2011-2-24 13:44:59 | 显示全部楼层
回复 6# helianalog
    RC都抽的。我没有改设置,都是默认值!您觉得是抽取参数的时候,设置的不对是吧?
发表于 2011-2-24 13:51:11 | 显示全部楼层
你可以只抽C或者RC都抽.
默认值可能都太小了,比如Rmin=0.001ohm, Cmin=0.01fF.
改成Rmin=0.1ohm, Cmin=1fF,
这样抽取的后仿网表文件会小些。
仿真时,你可以先看能不能快速的跑起来(比如power supply设定固定值,vco control voltage设置成最终稳定值附近),如果能跑起来,就是那进度条开始出现....的时候,再加你需要的激励。
不然等过了N长时间,就像你开始列出来那几条信息一样,还是跑不下去,时间就浪费了。
回复 支持 2 反对 0
 楼主| 发表于 2011-2-24 13:54:37 | 显示全部楼层
回复 8# helianalog
    好的啊,谢谢了!我再试试!
GMT+8, 2025-12-25 16:43 , Processed in 0.019629 second(s), 5 queries , Gzip On, Redis On.
