查看: 2531|回复: 3
[求助] 请教flash的烧写问题
发表于 2011-2-21 22:23:24 | 显示全部楼层 |阅读模式
本人初学FPGA,感觉有点困难,理不出头绪。现在对flash  AM29LV160DB  进行简单的擦除、读写操作,借用已有的用picoblaze写的flash控制器,我自己修改了下,怎么擦除都不成功,也不知道问题在哪,怎么调试修改。请教达人对flash的控制最基本应该注意的问题都有哪些?
发表于 2011-2-22 08:14:35 | 显示全部楼层
把代码贴到这,让大家帮着看一下
 楼主| 发表于 2011-2-23 16:10:55 | 显示全部楼层
这是部分擦除的程序
                           CONSTANT FLASH_data_in_port, 02        ;Read data from FLASH device
                           CONSTANT FLASH_data_out_port, 10       ;Data to write into FLASH device
                           CONSTANT FLASH_addr_hi_port, 80        ;FLASH address[23:16]
                           CONSTANT FLASH_addr_mi_port, 40        ;FLASH address[15:8]
                           CONSTANT FLASH_addr_lo_port, 20        ;FLASH address[7:0]
                           CONSTANT FLASH_control_port, 08        ;FLASH control
                           CONSTANT FLASH_read, 01                ;         active High read - bit0
                           CONSTANT FLASH_ce, 02                  ; active Low device enable - bit1
                           CONSTANT FLASH_we, 04                  ;         active Low write - bit2
                           NAMEREG sF, UART_data                  ;used to pass data to and from the UART
                           ;erase chip command sequence
                           LOAD s9, 00
                           LOAD s8, 0A
                           LOAD s7, AA
                           LOAD s1, AA
                           CALL FLASH_byte_write
                           LOAD s8, 05
                           LOAD s7, 55
                           LOAD s1, 55
                           LOAD s8, 0A
                           LOAD s7, AA
                           LOAD s1, 80
                           LOAD s8, 0A
                           LOAD s7, AA
                           LOAD s1, AA
                           LOAD s8, 05
                           LOAD s7, 55
                           LOAD s1, 55
                           LOAD s8, 0A
                           LOAD s7, AA
                           LOAD s1, 10
                           ;wait for erase to complete by polling status register
          chip_erase_loop: CALL FLASH_byte_read                   ;read status register
                           TEST s0, 80                            ;test MSB
                           JUMP NZ, end_chip_erase
                           LOAD UART_data, character_fullstop     ;progress dots
                           CALL send_to_UART
                           CALL delay_1s
                           JUMP chip_erase_loop
           end_chip_erase: CALL send_CR
                           CALL send_OK
                           JUMP prompt
         abort_chip_erase: CALL send_Abort
                           JUMP prompt
         FLASH_byte_write: OUTPUT s9, FLASH_addr_hi_port          ;set 24-bit address
                           OUTPUT s8, FLASH_addr_mi_port
                           OUTPUT s7, FLASH_addr_lo_port
                           OUTPUT s1, FLASH_data_out_port         ;set data byte to be written
                           LOAD s1, 00                            ;set controls
                           OUTPUT s1, FLASH_control_port
                           LOAD s1, 06                            ;>45ns delay
                           LOAD s1, 06                            ;  but do something useful by preparing register!
                           OUTPUT s1, FLASH_control_port          ;clear controls
                           RETURN
          FLASH_byte_read: OUTPUT s9, FLASH_addr_hi_port          ;set 24-bit address
                           LOAD s1, 05                            ;set controls
                           LOAD s1, 06                            ;>70ns delay
                           INPUT s0, FLASH_data_in_port           ;read data byte
                           RETURN
发表于 2011-2-24 09:08:35 | 显示全部楼层
O_O
不知道这里有没有看得懂的高人。
GMT+8, 2025-11-23 03:40 , Processed in 0.019103 second(s), 6 queries , Gzip On, Redis On.
