// S Y N T H E S I Z A B L E S D RA M C O N T R O L L E R C O RE
// This core adheres to the GNU Public License
// This is a synthesizable Synchronous DRAM controller Core. As it stands,
// it is ready to work with 8Mbyte SDRAMs, organized as 2M x 32 at 100MHz
// and 125MHz. For example: Samsung KM432S2030CT, Fujitsu MB81F643242B.
// The core has been carefully coded so as to be "platform-independent".
// It has been successfully compiled and simulated under three separate
// FPGA/CPLD platforms:
// Xilinx Foundation Base Express V2.1i
// Altera Max+PlusII V9.21
// Lattice ispExpert V7.0
// The interface to the host (i.e. microprocessor, DSP, etc) is synchronous
// and supports ony one transfer at a time. That is, burst-mode transfers
// are not yet supported. In may ways, the interface to this core is much
// like that of a typical SRAM. The hand-shaking between the host and the
// SDRAM core is done through the "sdram_busy_l" signal generated by the
// core. Whenever this signal is active low, the host must hold the address,
// data (if doing a write), size and the controls (cs, rd/wr).
verilog_SDRAM_core.rar
(27.76 KB , 下载次数:
398 )
