查看: 5586|回复: 10
[求助] SX与Cosmosscope的关系
发表于 2011-1-16 22:42:46 | 显示全部楼层 |阅读模式
都是synopysys的看波形的产品,不知道他们之间有什么区别?大大帮忙解释下!!!
发表于 2011-1-17 08:39:56 | 显示全部楼层
大不相同
由於是從兩個不同的公司來的
CosmosScope once belonged to a company named "Analogy."
Analogy had a mixed-signal simulation development environment called Saber.
Some time around the middle of the past decade (in 200x, 2003 or '04, I don't recall. ...), Synopsys acquired Analogy, so Saber and CosmosScope became part of Synopsys.
Syopsys acquired Sandwork in 2007.
So Sandwork SpiceExplorer became Synopsys SpiceExplorer since then.
Simply consider these two waveform viewers completely different and learn whichever you like.
发表于 2011-1-26 13:58:24 | 显示全部楼层
楼上正解,不过感觉二者都可以看hspice的波形
发表于 2011-2-15 13:11:06 | 显示全部楼层
学习了,谢谢
发表于 2011-3-7 22:27:15 | 显示全部楼层
sx用着不错,比cadence的wavescan好
发表于 2011-3-8 09:23:07 | 显示全部楼层
清楚了  謝謝
发表于 2011-3-8 14:56:02 | 显示全部楼层
我喜欢用sx
发表于 2011-3-13 20:25:09 | 显示全部楼层
学习了,谢谢
发表于 2014-7-9 20:48:15 | 显示全部楼层
Synopsys SpiceExplorer 现在的版本是多少?
发表于 2014-7-20 14:11:37 | 显示全部楼层
回复 1# asker
Does Hspice default has CScope with in it
GMT+8, 2025-10-17 01:24 , Processed in 0.022262 second(s), 8 queries , Gzip On, Redis On.
