查看: 7691|回复: 5
[求助] Altera Stratix-III上使用Megawizard产生的ALTMEMPHY在synthesis时报错
发表于 2011-1-10 15:08:07 | 显示全部楼层 |阅读模式
我使用Quartus-II的Megawizard产生了DDR SDRAM的PHY IP,即ALTMEMPHY,集成我的设计中后compiler没有问题,但是当synthesis时报如下错误,我都查了好久了也找不出问题所在,哪位高手有过经验的请不吝赐教,谢谢!
Error: Output port "O" of PSEUDO_DIFF_OUT primitive "ddr_phy:u_ddr_phy|ddr_phy_alt_mem_phy:ddr_phy_alt_mem_phy_inst|ddr_phy_alt_mem_phy_clk_reset:clk|DDR_CLK_OUT[0].mem_clk_pdiff" must drive only one OBUF primitive on the I port and cannot drive anything else File: D:/fpga/mega_ip/altmemphy/ddr_phy_alt_mem_phy.v Line: 5186
Warning: PLL "ddr_phy:u_ddr_phy|ddr_phy_alt_mem_phy:ddr_phy_alt_mem_phy_inst|ddr_phy_alt_mem_phy_clk_reset:clk|ddr_phy_alt_mem_phy_pll:full_rate.pll|altpll:altpll_component|altpll_17r3:auto_generated|pll1" has parameters clk0_multiply_by and clk0_divide_by specified but port CLK[0] is not connected
Error: Input port DATAIN of DDIO_IN primitive "ddr_phy:u_ddr_phy|ddr_phy_alt_mem_phy:ddr_phy_alt_mem_phy_inst|ddr_phy_alt_mem_phy_clk_reset:clk|ddio_mimic" must come from an I/O IBUF or DELAY_CHAIN primitive File: D:/fpga/mega_ip/altmemphy/ddr_phy_alt_mem_phy.v Line: 5099
 楼主| 发表于 2011-1-10 16:32:10 | 显示全部楼层
没有人知道么,自己顶一下
 楼主| 发表于 2011-1-11 15:21:48 | 显示全部楼层
顶起来,这个问题有点急
发表于 2011-1-11 22:59:18 | 显示全部楼层
你查查是不是管脚分配的问题。
 楼主| 发表于 2011-1-12 11:02:17 | 显示全部楼层
搞定了,谢谢楼上的。
是因为产生的ALTMEMPHY时有个tcl会配置管脚,而我设计中top层的管脚名与tcl中的命名不一致,没配上。
发表于 2011-9-14 13:11:16 | 显示全部楼层
我也遇到同样问题,期待答案!
GMT+8, 2025-12-18 08:59 , Processed in 0.023965 second(s), 7 queries , Gzip On, Redis On.
