查看: 4009|回复: 10
[资料] Quasi-Static Voltage Scaling for Energy Minimization With Time Constraints
发表于 2011-1-7 09:47:04 | 显示全部楼层 |阅读模式
Abstract—Supply voltage scaling and adaptive body biasing
(ABB) are important techniques that help to reduce the energy
dissipation of embedded systems. This is achieved by dynamically
adjusting the voltage and performance settings according to the
application needs. In order to take full advantage of slack that
arises from variations in the execution time, it is important to
recalculate the voltage (performance) settings during runtime, i.e.,
online. However, optimal voltage scaling algorithms are computationally
expensive, and thus, if used online, significantly hamper
the possible energy savings. To overcome the online complexity,
we propose a quasi-static voltage scaling (QSVS) scheme, with a
constant online time complexity 􀀀. This allows to increase the
exploitable slack as well as to avoid the energy dissipated due to
online recalculation of the voltage settings.
05291710.pdf (777.43 KB , 下载次数: 16 )
发表于 2011-1-7 11:24:37 | 显示全部楼层
谢谢共享!
发表于 2011-1-7 13:47:04 | 显示全部楼层
kan kan
发表于 2011-1-7 14:43:03 | 显示全部楼层
谢谢分享
发表于 2011-1-8 14:07:31 | 显示全部楼层
多谢楼主分享。
发表于 2011-1-8 14:18:01 | 显示全部楼层
谢谢啊
发表于 2011-1-8 23:06:37 | 显示全部楼层
Thanks!!!!
 楼主| 发表于 2011-1-13 17:10:01 | 显示全部楼层
不谢
发表于 2011-1-16 21:55:51 | 显示全部楼层
good, thanks.
发表于 2011-1-16 22:14:36 | 显示全部楼层
yes.yes.yes.thx
GMT+8, 2025-12-23 21:26 , Processed in 0.027086 second(s), 6 queries , Gzip On, Redis On.
