查看: 2126|回复: 4
[资料] ieee paper
发表于 2010-12-31 11:28:57 | 显示全部楼层 |阅读模式
A 32-Gb MLC NAND Flash Memory With Vth
Endurance Enhancing Schemes in 32 nm CMOS
Abstract—Novel program and read schemes are presented to
break barriers in scaling of NAND flash memory such as threshold
voltage endurance from floating gate interference, and charge loss
tolerance. To enhance threshold voltage endurance and charge loss
tolerance, we introduced three schemes; MSB Re-PGM scheme,
Moving Read scheme and Adaptive Code Selection scheme. Using
the MSB Re-PGM scheme, threshold voltage distribution width
is improved about 200 mV. The PGM throughput is enhanced
from 1500 s to 1250 s. With the Moving Read scheme about
half order of UBER is improved with 10 bit ECC. Also, Adaptive
Code Selection scheme are used to decrease a current consumption.
There is 5.5% current reduction. With these techniques,
32-Gb MLC NAND flash memory has been fabricated using
a 32 nm CMOS process technology. Its program throughput
reaches 13.0 MB/s at a multi-plane program operation with cache
operation keeping a desirable threshold voltage distribution.
05641590.pdf (3.9 MB , 下载次数: 15 )
发表于 2010-12-31 18:52:39 | 显示全部楼层
看不懂
发表于 2011-1-1 10:50:18 | 显示全部楼层
下来看看,谢谢。
发表于 2011-1-1 12:22:01 | 显示全部楼层
很好很强大
发表于 2011-1-1 22:12:17 | 显示全部楼层
谢谢啊
GMT+8, 2025-12-21 08:19 , Processed in 0.023783 second(s), 7 queries , Gzip On, Redis On.
