查看: 6748|回复: 1
[求助] 求教。。。后仿,加载SDF文件的时候报错
发表于 2010-12-19 20:25:45 | 显示全部楼层 |阅读模式
用MODELSIM做后仿
编译后 ,加载SDC的时候报错
warning:
# Loading pixel.sdf
# ** Warning: (vsim-SDF-3438) pixel.sdf(307): Annotating cell drivers of INTERCONNECT source port.
# ** Warning: (vsim-SDF-3438) pixel.sdf(308): Annotating cell drivers of INTERCONNECT source port.
# ** Warning: (vsim-SDF-3438) pixel.sdf(309): Annotating cell drivers of INTERCONNECT source port.
# ** Warning: (vsim-SDF-3438) pixel.sdf(310): Annotating cell drivers of INTERCONNECT source port.
# ** Warning: (vsim-SDF-3438) pixel.sdf(311): Annotating cell drivers of INTERCONNECT source port.
SDF中 是 这几行:这5个是我的 输出端口
(INTERCONNECT START_CLKI_REG/Q
START_CLKI (0.0005:0.0005:0.0005) (0.0005:0.0005:0.0005))
(INTERCONNECT START_RESET_REG/Q
START_RESET (0.0007:0.0007:0.0007) (0.0007:0.0007:0.0007))
(INTERCONNECT CLK_1M_REG/Q
CLK_1M (0.0006:0.0006:0.0006) (0.0006:0.0006:0.0006))
(INTERCONNECT TX_REG/Q
TX (0.0008:0.0008:0.0008) (0.0008:0.0008:0.0008))
(INTERCONNECT RST_REG/Q
RST (0.0008:0.0008:0.0008) (0.0008:0.0008:0.0008))
ERRO是:
# ** Error: (vsim-SDF-3262) pixel.sdf(332): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) pixel.sdf(352): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) pixel.sdf(372): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) pixel.sdf(392): Failed to find matching specify timing constraint.
#。。。。。。。。。。还有很多,每隔20行有个
# ** Error: (vsim-SDF-3262) pixel.sdf(848): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3445) Failed to parse SDF file "pixel.sdf".
Time: 0 ps
Iteration: 0
Region: /tb_pixel
File: E:/astro_post_sim/tb_pixel.v
# Error loading design
我找了下 SDF中是每个CELL的RECOVERR那一行 :
(TIMINGCHECK
(SETUP (posedge D) (posedge CK) (0.0:0.0:0.0))
(SETUP (negedge D) (posedge CK) (0.0:0.0:0.0))
(HOLD (posedge D) (posedge CK) (0.0:0.0:0.0))
(HOLD (negedge D) (posedge CK) (0.0:0.0:0.0))
(HOLD (posedge RN) (posedge CK) (0.0:0.0:0.0))
(RECOVERY (posedge RN) (posedge CK) (0.0:0.0:0.0))
   求教:这是什么问题啊?着急啊
发表于 2013-7-28 21:53:25 | 显示全部楼层
回复 1# shenmufan32
    兄弟,我也遇到了相似的问题。请问你的问题解决了吗, 谢谢。
GMT+8, 2025-12-16 05:14 , Processed in 0.034390 second(s), 6 queries , Gzip On, Redis On.
