查看: 2298|回复: 3
[资料] PIC Tutorial Hardware
发表于 2010-12-14 02:56:03 | 显示全部楼层 |阅读模式
The hardware required consists of a number  of small boards (built on Veroboard), which
connect together via ten pin leads using Molex connectors. The first board (Main Board) carries
the PIC16F628 processor and 5V regulator - the  board can be fed from a simple 9V battery.
Some of the later tutorials will require two processor boards, this is the reason for the second
connector on PortB - the two processors will communicate with each other over a standard 9600
baud serial bus, the second board can be either powered from the first (using a four wire
connection lead), or powered from it's own supply (using a three wire connection lead). The lead
consists of a ground wire, RB1 to RB2, RB2 to RB1, and an optional 5V wire. RB1 and RB2
cross over so we can experiment with the built-in hardware USART as well as software serial
communications.
Nigel tutorial.pdf (1.06 MB , 下载次数: 28 )
发表于 2010-12-14 08:14:25 | 显示全部楼层
good reference for PIC controller study
发表于 2011-5-15 13:39:00 | 显示全部楼层
Thanks.
发表于 2011-5-15 17:38:13 | 显示全部楼层
GMT+8, 2025-12-26 04:58 , Processed in 0.021313 second(s), 7 queries , Gzip On, Redis On.
