查看: 2228|回复: 0
[求助] 大虾 帮忙看下程序问题在哪
发表于 2005-7-8 15:13:12 | 显示全部楼层 |阅读模式
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity testctl is
port (                  clkk: in std_logic;
          cnt_en,rst_cnt,load: out std_logic);
end testctl;
architecture Behavioral of testctl is
     signal div2clk:std_logic;
begin
process(clkk)
begin
  if clkk'event and clkk='1' then div2clk<=not div2clk;
  end if;
end process;
process(clkk,div2clk)
begin
   if clkk='0' and div2clk='0' then rst_cnt<='1';
    else rst_cnt<='0';
   end if;
end process;
load<= not div2clk; cnt_en<=div2clk;
end Behavioral;
编译没有错误,但是仿真没结果,
好象是  “div2clk”在里面没起作用。
本人新手。 大虾帮忙看下,谢谢
GMT+8, 2025-12-28 09:45 , Processed in 0.017151 second(s), 9 queries , Gzip On, Redis On.
