查看: 29839|回复: 57
[资料] 0.35um技术CMOS各种工艺参数文档
发表于 2010-12-2 01:37:52 | 显示全部楼层 |阅读模式
0.35 μm CMOS C35 DFM Rules.pdf (169.47 KB , 下载次数: 497 )
0.35 μm CMOS C35 Noise Parameters.pdf (3.23 MB , 下载次数: 828 )
0.35 μm CMOS C35 Process Parameters.pdf (1.28 MB , 下载次数: 897 )
0.35 μm CMOS C35 RF SPICE Models.pdf (1.22 MB , 下载次数: 704 )
0.35μm CMOS C35 Matching Parameters.pdf (371.29 KB , 下载次数: 378 )
仅供参考
austriamicrosystems
发表于 2011-1-1 18:38:36 | 显示全部楼层
貌似可以下来看看
发表于 2011-5-27 19:36:13 | 显示全部楼层
下来看看吧
发表于 2011-7-5 19:36:13 | 显示全部楼层
对所有。35工艺都适用么?
发表于 2011-9-6 17:24:58 | 显示全部楼层
收藏看看,也分享给大家0.35um BCD的bipolar model:
section vnpn40
model vnpn40 bjt type=npn struct=vertical
+tnom=25              minr=1e-3                cjc=1.11335e-014
+cje=2.01739e-015    cjs=2.56542e-013    fc =0.5
+mjc=0.78039         mje=0.39825         mjs=0.35009
+vjc=0.5                 vje=0.80483         vjs=0.63703
+is =isn*0.986e-016  rb =20              re =30
+irb=0.1             rc =42.257          rbm=5
+nf =1.0679          vaf=77              ikf=0.00032245
+ne =2.1614          br =1.174           iss=6.5e-014
+nr =1.065           isc=4.6393e-016     tlev=0
+var=6.5             ikr=0.002           nkf=0.5
+nc =1.269           bf =bfn*48                ise=6.3348e-015
+xtb=0               xti=3.7403          eg =1.11
+tlevc  =1               tnf1=0               tnr1=0
+tne1=1.72e-005           tvar1  =0         tbf2=-5.7e-007
+tnc1=0.000168        tbf1=0.0075205       tbr1=0.00068139
+tikf1  =-0.0032         trb1=-0.006          trc1=-0.001516
+tbr2=-2.7e-006
endsection vnpn40
section lpnp40
model lpnp40 bjt type=pnp  struct=lateral
+tlev=0                      tlevc=1                      nf=1.008
+tnom=25                     minr=1e-3                        nc=1.37
+is=isp*1.5278e-16           bf=bfp*2.9862e2            vaf=240.579
+ikf=1.031942e-5             ise=5.215158e-16            isc=2.3516e-15
+ne=1.488968                 br=15.5                     nr=0.99366
+var=6.45414                 ikr=5.5104e-6               rbm=3.6
+rb=15.6                     irb=1e-3                    re=48.84
+cje=2.585e-14               vje=0.717                   mje=0.2323
+cjc=1.331e-13               vjc=0.4697                  mjc=0.2609
+cjs=0                       vjs=0.8137                  mjs=0.3509
+xcjc=1                      fc=0.5                      rc=5
+xtb=0                       xti=3.443301                eg=1.18
+tbf1=6.051737e-3            tbf2=6e-6                   tikf1=-4.45148e-3
+tikf2=8.9e-6                tne1=5e-5                   tbr1=3.864e-3
+tbr2=-6.48e-6               tre1=2e-4                   tre2=0
+trb1=0                      trb2=0
endsection lpnp40
发表于 2012-3-11 14:56:17 | 显示全部楼层
谢谢楼上各位
发表于 2012-3-24 11:14:13 | 显示全部楼层
谢谢   下来看看
发表于 2012-3-24 16:25:37 | 显示全部楼层
thnaks!!!!!!!!!!!!!!
发表于 2012-3-24 16:41:29 | 显示全部楼层
很好,下来看看
发表于 2012-5-23 10:45:42 | 显示全部楼层
感谢分享~~正在找这个参数的数据.
GMT+8, 2025-12-14 13:11 , Processed in 0.020503 second(s), 6 queries , Gzip On, Redis On.
