查看: 3416|回复: 3
[求助] 做“测试”还是做“版图”?
发表于 2010-11-19 21:52:00 | 显示全部楼层 |阅读模式
最近碰到个难题,我在foundry做了几年,最近有个机会去模拟设计公司做应用测试(application engineer)或者版图(layout engineer),到底应该选择哪个呢?做版图据说发展比较窄,应用的测试以后的发展好一些,是这样吗?
请大家帮忙出出主意吧,不胜感激!
发表于 2010-12-3 21:43:41 | 显示全部楼层
测试具体是什么工作内容?如果是做测试电路板的话我觉得还是比较有挑战性的
发表于 2010-12-4 20:57:55 | 显示全部楼层
回复 1# ygyg100
If your background is EE, I think you should select application engineer,
because you can learn much and do the new job well easier.
Otherwise, if your background is not EE, I suggest you select layout engineer,
because it is a very professional skill but it needs not much EE backgound.
Just FYR.
发表于 2010-12-6 16:25:43 | 显示全部楼层
测试吧,比较好跳槽。
GMT+8, 2025-12-25 12:15 , Processed in 0.019676 second(s), 5 queries , Gzip On, Redis On.
