楼主: sh_0119
[求助] DC综合中compile和compile_ultra有什么区别?
发表于 2014-5-26 10:09:00 | 显示全部楼层
goodood
发表于 2014-6-1 18:49:40 | 显示全部楼层
我看过一本关于DC综合的书,书中说使用compile_ultra命令综合后的时序更好,但是面积可能会比使用compile命令综合后的面积更大,求正解!
发表于 2014-7-29 11:05:56 | 显示全部楼层
very good
发表于 2014-10-2 08:31:04 | 显示全部楼层
rerere
发表于 2015-12-1 19:39:15 | 显示全部楼层
大神们多多分享啊
发表于 2016-4-8 10:32:05 | 显示全部楼层
compile_ultra用不了啊,谁有licence可以分享一下吗
发表于 2016-5-12 15:18:45 | 显示全部楼层
正确解答如下:
Default compile_ultra Optimizations:
■Performs three levels of optimization:
• Architectural level or high level synthesis
• Logic level or GTECH optimization
• Gate-level or mapping optimization
■ Tries to minimize area while meeting timing
(and other) constraints1
■ When used in Topo mode, performs underthe-
hood placement and routing estimation
to calculate net RCs
■ Requires an Ultra license as well as a
DesignWare license (explained shortly)
■ Invokes additional high performance
optimization algorithms (examples follow)
By default, compile ultra uses a max_area constraint of zero. The area constraint always
has the lowest priority during optimization, compared to timing, design rule or power constraints. If the -timing^high^ef f ort_script option is not used with c om p ile _ u ltra ,_ th e n areafocused optimizations7which were enabled with -area_high ef f ort_script prior to version
2010.03, are now automatically invoked. This does not increase The priority of timing over other
constraints - it simply applies additional area-optimizing algorithms.
发表于 2016-5-13 09:42:11 | 显示全部楼层
一般现在都用compile_ultra,实在不好再来几次incremental
发表于 2016-5-22 10:45:14 | 显示全部楼层
感觉得需要认真的看看ug
发表于 2016-6-21 20:15:34 | 显示全部楼层
顶贴赚积分
GMT+8, 2025-12-31 00:39 , Processed in 0.020401 second(s), 3 queries , Gzip On, Redis On.
