查看: 5549|回复: 4
求救---centos5.5 安装ic610的问题
发表于 2010-10-29 19:42:51 | 显示全部楼层 |阅读模式
在安装installscape时遇到下面的
Extracting InstallScape version 03.40.p06
for platform lnx86 in /home/eda/installscape
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0
If you do not see the InstallScape console
window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/eda/installscape/iscape/bin/iscape.sh /mnt/hgfs/share/ic/IC610_lnx86.Base/CDROM1:::/home/eda/ic610
Initializing InstallScape using JVM at /home/eda/installscape/iscape/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/eda/installscape/iscape/runtime/LNX86/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1503)
        at java.lang.Runtime.loadLibrary0(Runtime.java:788)
        at java.lang.System.loadLibrary(System.java:834)
        at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:50)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.awt.Toolkit.loadLibraries(Toolkit.java:1437)
        at java.awt.Toolkit.<clinit>(Toolkit.java:1458)
        at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:70)
-------------------------------------------------------------------------------------------------------”,请问为什么会出现这样的提示,该如何解决啊?
 楼主| 发表于 2010-10-30 11:16:47 | 显示全部楼层
回复 1# xuyuejiang
    此问题已解决,缺少一个依赖包libxp
发表于 2012-8-17 20:10:18 | 显示全部楼层
能说明一下解决过程吗
发表于 2012-8-19 09:39:39 | 显示全部楼层
给你推荐个网站 这里能够搜到各种linux系统中缺少的各种库文件
http://rpm.pbone.net/
在网站中选择search 然后搜 libXp.so.6会出现很多版本的rpm安装包  选择针对你系统的版本 进行安装
这样问题就解决了
发表于 2012-11-7 16:25:54 | 显示全部楼层
大神啊。。。。学习了
能不能分享一下ic610的license,谢谢
673713048@qq.com
GMT+8, 2025-12-14 16:15 , Processed in 0.020643 second(s), 6 queries , Gzip On, Redis On.
