查看: 10194|回复: 11
[求助] 我安装了ic610,画版图有问题
发表于 2015-6-26 14:39:41 | 显示全部楼层 |阅读模式
好不容易安装好了ic610,画原理图也没有问题,但是画版图的时候又出问题了,下面是我的报错,,有没有人知道该怎么解决。。
An error occured while initializing the libInit.il file.
The library, tsmc18rf, specified in this file, could
not be found. If you have:
    o   moved/copied the library to a new name.
    o   edited this file and made a typographical error.
    o   copied this file from another library.
you must edit the libInit.il file and correct the
library name.
Loading oasis.cxt
ERROR (ADE-5066): Tool 'hspiceS' has not been registered.
ERROR (ADE-5067): Unable to initialize tool 'hspiceS'; either tool class is not
        defined or tool is not registered.
*Error* The default SKILL generic function has not been defined for the function "asiSetNetlistOption". Ensure that this function is called with the correct argument(s) (tool name value).
Loading lo.cxt
Loading see.cxt
Loading treeAssistant.cxt
Loading oi.cxt
Loading techComp.cxt
*WARNING* Pcell evaluation for tsmc18rf_OA/nmos2v/layout has the following error(s):
*WARNING* ("eval" 3 t nil ("*Error* eval: undefined function" snapToGrid))
*WARNING* Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
*WARNING* Pcell evaluation for tsmc18rf_OA/pmos2v/layout has the following error(s):
*WARNING* ("eval" 4 t nil ("*Error* eval: undefined function" snapToGrid))
Library Manager deleting cellview "inv/sche/layout".
Loading layers.cxt
Deleted cellview 'inv/sche/layout'.
(virtuoso) Syncing library list with the Library Manager.
Loading lx.cxt
Loading schematic.cxt
Loading ci.cxt
Loading cph.cxt
VXL timing: Enable extractor time = 0.00 seconds
INFO (BND-1002): Binder initialization report:
  Schematic instances with corresponding layout instances:   0
  Layout instances with corresponding schematic instances:   0
  Layout instances with no corresponding schematic instance: 0
  Instances present in schematic but missing from layout:    2
VXL timing: Initialization time = 0.01 seconds
Loading vfp.cxt
Loading vcpfe.cxt
Building the layout generation form takes a moment...
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M0' because the instance master 'tsmc18rf_OA/nmos2v/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M0' because the instance master 'tsmc18rf_OA/nmos2v/layout' does not have a corresponding terminal 'D'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M0' because the instance master 'tsmc18rf_OA/nmos2v/layout' does not have a corresponding terminal 'G'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M0' because the instance master 'tsmc18rf_OA/nmos2v/layout' does not have a corresponding terminal 'S'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M1' because the instance master 'tsmc18rf_OA/pmos2v/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M1' because the instance master 'tsmc18rf_OA/pmos2v/layout' does not have a corresponding terminal 'D'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M1' because the instance master 'tsmc18rf_OA/pmos2v/layout' does not have a corresponding terminal 'G'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M1' because the instance master 'tsmc18rf_OA/pmos2v/layout' does not have a corresponding terminal 'S'.
*WARNING* (LX-2006): There were errors or warnings during layout generation.
INFO (LX-1030): Run Connectivity - Check - Against Source for more details.
VXL timing: Layout generation time = 1.03 seconds
INFO (LX-1024): Instance parameters match.
INFO (LX-1032): There are differences between the layout and the schematic.
Check messages above for details.
 楼主| 发表于 2015-6-30 17:04:58 | 显示全部楼层
没有帮我解决一下吗?
发表于 2015-7-3 17:00:26 | 显示全部楼层
tsmc18rf没有,你要添加一个PDK库吧?
 楼主| 发表于 2015-7-9 10:30:09 | 显示全部楼层
是不是我将CDB的工艺库转换成OA格式以后必须将OA格式的库重命名为tsmc18rf?
发表于 2016-7-8 18:41:03 | 显示全部楼层
回复 4# 毅小祥
我也碰到了一部分问题,复制log如下:
Initializing from libInit.il for library tsmc18rf...
   --  tsmc18rf_updateCDFs.ile
   --  tsmc18rf.cxt
Loading Working place Display File '/home/lugy/TSMC018RF/design/Untitled/display.drf'
Loading oasis.cxt
Loading oi.cxt
Loading see.cxt
Loading asst.cxt
Loading mtv.cxt
不知道是什么情况,强迫症伤不起。。。
发表于 2017-9-11 16:27:51 | 显示全部楼层
回复 5# iclugy
请问这个问题解决了吗?怎么解决的?
发表于 2017-9-11 17:34:17 | 显示全部楼层
回复 5# iclugy
你好,这个问题解决了吗?怎么解决的?
发表于 2019-4-13 23:17:38 | 显示全部楼层
iclugy 发表于 2016-7-8 18:41
回复 4# 毅小祥
我也碰到了一部分问题,复制log如下:
解决了吗老哥?
发表于 2019-11-21 15:38:04 | 显示全部楼层
回复 4# 毅小祥
我也碰到了一部分问题,复制log如下:
没解决掉,也忘记怎么个情况了,大家可以忽略我的信息。抱歉。
发表于 2020-5-30 12:03:45 | 显示全部楼层
遇到同样的问题,现在急着画版图,请问怎么解决?
GMT+8, 2025-12-26 05:14 , Processed in 0.025086 second(s), 5 queries , Gzip On, Redis On.
