查看: 2156|回复: 1
【诚聘】High Speed Analog PCB Design Engineer
发表于 2010-10-25 18:10:49 | 显示全部楼层 |阅读模式
美资公司LSI上海研发中心高薪诚聘通讯存储领域人才,薪水待遇优厚,今年开始配股了,部分人员有出国培训机会。(部门内部推荐,成功机会更高)
有意者请将中英文简历发送至:asic_tapeout@hotmail.com
High-Speed Analog PCB Design Engineer
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
LSI Corporation is a leading provider of innovative silicon, systems and software technologies that enable products which seamlessly bring people, information and digital content together.This position is part of the LSI's world-lead head-to-host recording system design validation team, and focus on high speed pre-amplifier validation PCB design.
The tasks include: perform PCB design & layout process (starting from schematics level to bring the layout to final completion of checking LVS and DRC), manufacture support, debugging of the PCB board, and basic high speed test.
PREFERRED EXPERIENCE:
· Bachelor or Master degree in Electronics/Electrical Engineering with minimum 3 years of high speed PCB design
· Demonstrated ability to design controlled impedance paths for high speed signal(single and differential, 4GHZ +) including tapping to chip unit for lineout.
· Good hands on knowledge of Altium tools. Experience with PCAD or Cadence Allegro design tool is also desired. And circuit analysis simulation tool in signal integrity is a plus.
· Deep understanding of manufacturing, flip chip soldering and mounting processes for PCB
· Fundamental knowledge on high speed test knowledge (e.g. TDR, s-parameter, De-Embedding methodology), transmission line theory and circuit analysis is required.
· Proven skills using electronic measurement equipment in a lab environment
· Expertise in applied magnetism and recording a strong plus
· Good oral and written communications in English skills are required
 楼主| 发表于 2010-11-22 17:06:06 | 显示全部楼层
回复 1# asic_tapeout
    还有一个空缺
GMT+8, 2025-12-22 09:42 , Processed in 0.523517 second(s), 6 queries , Gzip On, Redis On.
