查看: 2399|回复: 3
[资料] How Radar Works
发表于 2010-10-20 01:13:57 | 显示全部楼层 |阅读模式
 楼主| 发表于 2010-10-20 01:16:31 | 显示全部楼层
回复 1# chaowen54
    A basic radar system is spilt up into a transmitter, switch, antenna, receiver, data recorder, processor and some sort of output display.  Everything starts with the transmitter as it transmits a high power pulse to a switch which then directs the pulse to be transmitted out an antenna.  Just after the antenna is finished transmitting the pulse, the switch switches control to the receiver which allows the antenna to receive echoed signals.  Once the signals are received the switch then transfers control back to the transmitter to transmit another signal.  The switch may toggle control between the transmitter and the receiver as much as 1000 times per second.
发表于 2010-11-26 10:17:00 | 显示全部楼层
thank you very much
发表于 2011-3-3 09:33:26 | 显示全部楼层
ddddddddddddddddd
GMT+8, 2025-12-22 17:35 , Processed in 0.013750 second(s), 4 queries , Gzip On, Redis On.
