查看: 4469|回复: 2
[求助] 请帮忙看看以下几个名称的具体含义:minWC, avgTW
发表于 2010-10-12 13:23:27 | 显示全部楼层 |阅读模式
我没做过后端的东西
最近看一些资料设计到一些名词,帮忙看看是什么意思
谢谢
minWC
maxTW
avgTW
CTS
发表于 2010-10-12 16:28:30 | 显示全部楼层
CTS
clock tree synthes
 楼主| 发表于 2010-10-13 12:51:34 | 显示全部楼层
谢谢。
我已经大概知道maxTW,avgTW的含义。
"avgTW", average effective voltage (Vdd-Vss) over the timing window, “minTW”, minimum effective voltage over the timing window, “maxTW”, maximum effective voltage over the timing window.
只是minWC还是没有概念。
下面给个上下文语境,希望各位帮忙参详一下。
it reports the worst percentage DvD values for all arcs for the
selected base parameter (default avgTW). You can select a different base value,
since the worst MinTW, maxTW, or minWC values from one arc may not be the
worst among multiple arcs for the same instance.
GMT+8, 2025-12-21 21:13 , Processed in 0.102291 second(s), 5 queries , Gzip On, Redis On.
