查看: 3005|回复: 1
VHDL新手问题
发表于 2006-10-2 11:12:01 | 显示全部楼层 |阅读模式
请问各位,怎样用VHDL描述一个可变输入数目(用generic)的multiplexer?
我写不出architecture
library        ieee;
use        ieee.std_logic_1164.all;
package mytype is
        type vector_array is array(natural range<>) of std_logic_vector(7 downto 0);
end package;
library        ieee;
use               work.mytype.all;
entity mux501 is
        generic(n: integer:= 2);
        port(din: in vector_array(0 to 2**n-1);
        sel: in integer range 0 to 2**n-1;
        dout: out std_logic_vector(7 downto 0));
end mux501;
architecture mux501_arch of mux501 is
begin
    --不知道怎么写?
end mux501_arch;
不胜感谢!!!!
发表于 2006-10-5 00:32:38 | 显示全部楼层
faint,如果端口位宽和端口数目都可变,那就用FOR LOOP和ARRAY INDEX;如果只是端口数目可变(本例),就直接用ARRAY INDEX....
GMT+8, 2025-12-23 22:33 , Processed in 0.019072 second(s), 6 queries , Gzip On, Redis On.
