查看: 7689|回复: 15
ubuntu 10.3 安装 vcs?
发表于 2010-10-8 07:11:42 | 显示全部楼层 |阅读模式
我原来安装过一次,好像最后报错,就装了centos+vcs. 现在看到还是有很多人用  ubuntu. 各位大侠怎么解决的?
发表于 2010-10-8 07:50:32 | 显示全部楼层
Newest Ubuntu stable version is 10.04.1.
I have tried to set up VCS 2009.06 & VCS MX 2009.12 on Centos and RHEL 5.5 but not success. But I had success with Ubuntu.
dve
dve
 楼主| 发表于 2010-10-8 08:01:43 | 显示全部楼层
right, i tried on 10.3, not 13. but error reported on the last step, maybe some libs missing
 楼主| 发表于 2010-10-8 08:04:32 | 显示全部楼层
the failure is like this:
我在ubuntu8.10 desktop系统上安装synopsys vcs, 可是总是安装到快结束时失败。
install.log中显示出错信息如下:
DO_INSTALL /home/atlas/EDA/synopsys/vcs_vA-2008.09-3/VMS/admin/install.sh -r /home/atlas/EDA/synopsys/vcs_vA-2008.09-3
ERROR : Failed to
execute /home/atlas/EDA/synopsys/vcs_vA-2008.09-3/VMS/admin/install.sh
ERROR :
Start VMS/admin/install.sh
untar var.tar.gz ...
untar samples.tar.gz ...
setting synopsys_rman.setup ...
To install and customize full Execution Manager capability,
please run following command
%/home/atlas/EDA/synopsys/vcs_vA-2008.09-3/VMS/admin/post_install.sh
VCS customers who do not want to use Execution Manager
can ignore this
chmod: cannot access `var': No such file or directory
 楼主| 发表于 2010-10-8 11:21:51 | 显示全部楼层
no one knows?
发表于 2010-10-8 11:37:24 | 显示全部楼层
thanks
发表于 2010-10-8 20:09:52 | 显示全部楼层
I can help you
 楼主| 发表于 2010-10-9 00:11:13 | 显示全部楼层
thanks
发表于 2011-1-12 13:44:54 | 显示全部楼层
我遇到了一模一样的问题,
请问你们是如何解决的?
是需要添加一个库文件么?
能否讲一下?
发表于 2011-1-12 20:27:09 | 显示全部楼层
不用理会即可,VCS可正常使用
GMT+8, 2025-12-30 00:09 , Processed in 0.025240 second(s), 7 queries , Gzip On, Redis On.
