查看: 2232|回复: 0
编了一个switch的vhdl程序,欢迎指正!
发表于 2005-5-25 14:58:00 | 显示全部楼层 |阅读模式
LIBRARY IEEE;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY switch IS
  PORT (CE,CLK: IN STD_LOGIC;
        DIN: IN STD_LOGIC_VECTOR(7 DOWNTO 0);
        DOUT: OUT STD_LOGIC_VECTOR(15 DOWNTO 0));
END switch;
ARCHITECTURE switch_arch OF switch IS
SIGNAL indata:IN BIT;
BEGIN
indata<=CE
F1ROCESS(CLK)
BEGIN
   IF(CLK'EVENT AND CLK='1')THEN
     CASE indata IS
     WHEN "0" => DOUT(7 DOWNTO 0) <= DIN;
     WHEN "1" => DOUT(15 DOWNTO 8) <=DIN;
     END CASE;
   END IF;
END PROCESS F1;
END switch_arch;
GMT+8, 2025-12-27 00:35 , Processed in 0.021054 second(s), 7 queries , Gzip On, Redis On.
