查看: 10868|回复: 31
Help Synplify 2010.03 linux
发表于 2010-10-4 06:18:59 | 显示全部楼层 |阅读模式
hi friends
well, i ve downloaded synplify 2010.06 for linux from this forum, and installed it without any problem. I m using ubuntu 10.04 but also with redhat 4.7 it didn t work.
The Environment Variables that i made:
  1. # Synplify 2010.03
  2. export PATH=$SYNOPSYS_HOME/Synplify_2010.03/linux/mbin:$SYNOPSYS_HOME/Synplify_2010.03/linux/lib:$SYNOPSYS_HOM/Synplify_2010.03/linux:$PATH
  3.
    复制代码
executing synplify gives me:
  1. >> synplfy
  2.   synplify: symbol lookup error: synplify: undefined symbol: _Z13qFlagLocationPKc
  3.
    复制代码
so i modified the environment in order to load all dependencies ( as was found in some forums) by adding:
  1. export LD_LIBRARY_PATH=$SYNOPSYS_HOME/Synplify_2010.03/linux/lib/
  2.
    复制代码
after setting environment, i launch synplify,  nothing happen,
>> ldd $synplify
  1. linux-gate.so.1 =>  (0x006dd000)
  2. libutil.so.1 => /lib/tls/i686/cmov/libutil.so.1 (0x00639000)
  3. libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0x00955000)
  4. libtcl8.4.so => /usr/lib/libtcl8.4.so (0x00ce7000)
  5. libQtCore.so.4 => /usr/lib/libQtCore.so.4 (0x00110000)
  6. libQtGui.so.4 => /usr/lib/libQtGui.so.4 (0x00de2000)
  7. libQtNetwork.so.4 => /usr/lib/libQtNetwork.so.4 (0x0038e000)
  8. libQtXml.so.4 => /usr/lib/libQtXml.so.4 (0x006f4000)
  9. libQtAssistantClient.so.4 => /usr/lib/libQtAssistantClient.so.4 (0x007ab000)
  10. libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0x004b5000)
  11. libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0x004ce000)
  12. libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0x007b3000)
  13. /lib/ld-linux.so.2 (0x00dc5000)
  14. libz.so.1 => /lib/libz.so.1 (0x004f4000)
  15. libgthread-2.0.so.0 => /usr/lib/libgthread-2.0.so.0 (0x00509000)
  16. librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0x0050f000)
  17. libglib-2.0.so.0 => /lib/libglib-2.0.so.0 (0x009f0000)
  18. libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00518000)
  19. libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x0060e000)
  20. libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x0063d000)
  21. libaudio.so.2 => /usr/lib/libaudio.so.2 (0x009a2000)
  22. libpng12.so.0 => /lib/libpng12.so.0 (0x0066d000)
  23. libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00abc000)
  24. libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x00692000)
  25. libSM.so.6 => /usr/lib/libSM.so.6 (0x0062d000)
  26. libICE.so.6 => /usr/lib/libICE.so.6 (0x00739000)
  27. libXrender.so.1 => /usr/lib/libXrender.so.1 (0x00993000)
  28. libXext.so.6 => /usr/lib/libXext.so.6 (0x006de000)
  29. libX11.so.6 => /usr/lib/libX11.so.6 (0x00b34000)
  30. libpcre.so.3 => /lib/libpcre.so.3 (0x00752000)
  31. libexpat.so.1 => /lib/libexpat.so.1 (0x00783000)
  32. libXt.so.6 => /usr/lib/libXt.so.6 (0x00c51000)
  33. libXau.so.6 => /usr/lib/libXau.so.6 (0x006d5000)
  34. libuuid.so.1 => /lib/libuuid.so.1 (0x006ee000)
  35. libxcb.so.1 => /usr/lib/libxcb.so.1 (0x0090d000)
  36. libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00927000)
    复制代码
So dear friends, do you have any idea how could i solve this problem. or if have already made it work, could you tell me what steps have you made?
thanks in advance
发表于 2010-10-4 07:06:29 | 显示全部楼层
发给我,我帮你试一下
发表于 2010-10-4 07:09:54 | 显示全部楼层
我弄过03的,没弄过06的,
 楼主| 发表于 2010-10-4 07:16:31 | 显示全部楼层
发表于 2010-10-4 07:17:41 | 显示全部楼层
就按照网上弄的,没弄过06的,可能有点变化
 楼主| 发表于 2010-10-4 07:22:20 | 显示全部楼层
could you please write in English as i dont understand Chinese and i m sorry for that.
and when i translate in "google translate" it not very good
发表于 2010-10-4 07:51:36 | 显示全部楼层
We don't understand English.
 楼主| 发表于 2010-10-4 08:15:32 | 显示全部楼层
down_load 发表于 2010-10-4 07:51
dear friend
    I apology not to know Chinese, my mistake, also i m not an English man . So in order to communicate the best is to talk english otherwise we can't understand each other.
So do you have any idea how i could solve this problem.
Thanks in advance
 楼主| 发表于 2010-10-6 07:55:54 | 显示全部楼层
please help
发表于 2010-10-6 15:18:44 | 显示全部楼层
QT library problem !!.......... update to Red Hat Enterprise Linux 5.X !!
CentOS 5.X  (same as Red Hat Enterprise Linux but free)
http://www.centos.org/
GMT+8, 2025-12-17 02:29 , Processed in 0.024078 second(s), 7 queries , Gzip On, Redis On.
