查看: 2420|回复: 2
[求助] VERILOG仿真求教
发表于 2010-9-22 22:03:26 | 显示全部楼层 |阅读模式
此程序是简单的状态机,在仿真的时候K2和K1的值是未知数X,请高手赐教
module fsm(Clock,Reset,A,K2,K1,state);
input Clock,Reset,A;
output K2,K1;
output [1:0]state;
reg K2,K1;
reg [1:0]state;
parameter Idle=2'b00,
          Start=2'b01,
          Stop=2'b10,
          Clear=2'b11;
   always @(posedge Clock)
      if(!Reset)
         begin
            state<=Idle;
            K2<=0;
            K1<=0;
        end
      else
         casex(state)
             Idle:if(A) begin
                          state<=Start;
                          K1<=0;
                      end
                       else begin
                           state<=Idle;
                           K2<=0;
                           K1<=0;
                       end
             Start:if(!A) state<=Stop;
                    else state<=Start;
             Stop:if(A) begin
                          state<=Clear;
                          K2<=1;
                      end
                  else begin
                         state<=Stop;
                         K2<=0;
                         K1<=1;
                     end
             Clear:if(!A) begin
                             state<=Idle;
                             K2<=0;
                             K1<=1;
                         end
                   else begin
                          state<=Clear;
                          K2<=0;
                          K1<=0;
                      end
             default:state<=Idle;
     endcase
endmodule
测试代码
`timescale 1ns/1ns
module test;
    reg a;
    reg clock,rst;
    wire k2,k1;
initial
   begin
       a=0;
       rst=1;
       clock=0;
       #22 rst=0;
       #133 rst=1;
   end
   always #50 clock=~clock;
   always @(posedge clock)
      begin
          #30 a={$random}%2;
          #(3*50+12);
      end
      initial
      begin
      #10000 $stop;
      end
   fsm m(.Clock(clcok),.Reset(rst),.A(a),.K2(k2),.K1(k1));
endmodule
发表于 2010-9-23 08:20:54 | 显示全部楼层
(.Clock(clcok),.
 楼主| 发表于 2010-9-23 12:20:03 | 显示全部楼层
谢谢了
GMT+8, 2025-12-2 17:06 , Processed in 0.444825 second(s), 5 queries , Gzip On, Redis On.
