楼主: 华憨
[原创] 有关国外的硬件木马(hardware Trojan horse)技术
发表于 2010-9-14 08:31:53 | 显示全部楼层
还真没听说过。
关键是怎么发送给接收者?得 有发送电路吧。
发表于 2010-9-16 00:28:55 | 显示全部楼层
下来研究一下
发表于 2010-9-20 15:44:31 | 显示全部楼层
芯片木马
发表于 2010-9-20 15:45:34 | 显示全部楼层
芯片木马
发表于 2010-10-18 15:30:12 | 显示全部楼层
看看。
发表于 2010-10-19 15:59:56 | 显示全部楼层
很好,谢谢
发表于 2010-10-19 22:15:03 | 显示全部楼层
因为现在的芯片都是在FOUNDARY 厂做的,所以在芯片上空闲的地方有可能被人插入恶意电路
我也要学习这个
发表于 2010-10-21 14:01:21 | 显示全部楼层
楼主好人,正需要这方面的资料,谢谢了
发表于 2010-10-21 14:03:21 | 显示全部楼层
楼主好人,正需要这方面的资料,谢
发表于 2010-10-21 22:28:20 | 显示全部楼层
Hi friends,
The problem with that is that the spy should have access to the end market a priori.
So the use of this technologies can be done in a very limited way.
The problem with this kind of trojen horses is that you have to have physical access to the hardware infrastructure at design time and that's not always possible.
That's why soft trojans are more effective. They run on standard hardware and are installed/activated remotely.
I'm not telling that HW trojans are useless. I'm just saying that their use is much more limited and the "niche" is very small.
By the way, hardware trojans exist for a while now. and many technologies contained them and still contain them
GMT+8, 2025-9-13 19:10 , Processed in 0.017983 second(s), 3 queries , Gzip On, Redis On.
