楼主: angelweishan
[资料] RESEARCH AND DESIGN OF LOW JITTER, WIDE LOCKING-RANGE All Digital PLL & DLL
发表于 2011-9-8 13:36:39 | 显示全部楼层
嗯,是博士论文。
发表于 2011-9-8 22:41:26 | 显示全部楼层
謝謝分享
发表于 2011-9-10 13:27:13 | 显示全部楼层
A Harmonic-free and Fast-locking Delay-Locked Loop Adopting a Resettable Delay Line
发表于 2011-9-10 23:33:12 | 显示全部楼层
Abstract
PHASE-LOCKED loops (PLLs) and delay-locked loops (DLLs) are often used in integrated
circuits in order to compensate for clock distribution delays and to improve overall system
timing. PLLs are also widely used in clock recovery and frequency synthesis. When
compared to traditional implementations of PLLs and DLLs, an all-digital approach will be
found more suitable for monolithic implementation on the same die with other digital
circuits. A robust, process-independent performance is expected using all digital techniques.
In this dissertation, several aspects of phase-locked and delay-locked loops are
investigated, including building blocks, loop dynamics, noise and jitter. General design
criteria are summarized for the all-digital implementation with the comparison to the
traditional approaches and popular charge-pump analog implementation.
An all-digital phase-locked loop (ADPLL) using a proposed register-controlled
oscillator (RCO) and all-digital phase frequency detector (PFD) is developed and fabricated
using 0.18um CMOS technology. The two-loop architecture, hierarchy pull-in process and
fine phase adjustment make this RCO-based ADPLL achieve less than 80-cycle lock time,
65MHz-385MHz lock range, 30ps RMS jitter and less than 2% duty cycle distortion when
the reference clock is at 200MHz. This ADPLL also shows stable operation when power
supply voltage is down to 1.4V, which gives more flexibility in low power applications
without significant design modification.
A register-controlled symmetrical DLL (RSDLL), targeted for clock synchronization
and de-skewing in double-data rate synchronous DRAM, is implemented based on a
symmetrical register-controlled delay line. This RSDLL was fabricated using 0.21μm
CMOS technology and achieved 50ps RMS jitter when the operating frequency is in the
range of 125MHz to 250MHz. This approach eliminates extra circuitry for duty cycle
correction when using both rising and falling edges to latch data. Measurement results are
presented to verify its robust operation under different voltage and temperature conditions.
发表于 2011-9-11 00:23:55 | 显示全部楼层
THANKS A LOT
发表于 2011-10-22 14:15:03 | 显示全部楼层
good
3q3q for share
发表于 2011-10-27 20:32:33 | 显示全部楼层
tks 4shainfg~
发表于 2012-2-8 08:13:27 | 显示全部楼层
感谢共享!!!!
发表于 2012-4-13 01:43:18 | 显示全部楼层
很好的东西,非常感谢。。
发表于 2012-8-17 23:50:16 | 显示全部楼层
GOOOOOOOOOOOOOOOOOOOOD
GMT+8, 2025-12-20 10:36 , Processed in 0.019196 second(s), 2 queries , Gzip On, Redis On.
