楼主: richchen00
做版图 cmos bipolar bicmos 要都精通吗?
发表于 2010-4-4 23:44:28 | 显示全部楼层
后端发sci?
发表于 2010-4-5 06:21:48 | 显示全部楼层
The true analog designer need to know both!
发表于 2010-6-17 09:34:56 | 显示全部楼层
You should have the experiences of layout.
发表于 2010-6-18 11:50:37 | 显示全部楼层
be accomplished in what you are doing, be familiar with the correlative knowledge.
发表于 2010-6-18 12:24:04 | 显示全部楼层
学习了。。
发表于 2010-7-2 20:30:07 | 显示全部楼层
kan kan
发表于 2010-10-8 17:33:56 | 显示全部楼层
If you are a process integration engineer -- you must know the different among them.
1. bipolar -- simple circuit with higher output capability ---
2. cmos -- for high density circuits with lower power consumption
3. bicmos-- one for power managerment -- cmos do the controler, bjt do the output
                  the other can do the RF circuit.
the latout related to circuit, but for special device, the foundry will provide you the standard cell.
发表于 2010-12-5 21:32:58 | 显示全部楼层
dajia de yingyu dou hao lihai a !
发表于 2010-12-6 09:23:54 | 显示全部楼层
那要看你做那一種產品應用
发表于 2010-12-6 14:19:10 | 显示全部楼层
xuexi...
GMT+8, 2025-9-14 16:56 , Processed in 0.017938 second(s), 5 queries , Gzip On, Redis On.
