查看: 7143|回复: 15
[资料] Applications of polyphase filters for bandpass sigma-delta ADC
发表于 2010-8-4 09:27:22 | 显示全部楼层 |阅读模式
Applications of polyphase filters for bandpass sigma-delta analog-to-digital conversion.
Abstract
The traditional lowpass Sigma-Delta  based Analog-to-Digital (A/D) conversion
principle has been recently extended to bandpass for direct IF conversion. Such converter offers high Signal-to-Noise (SNR) ratios for narrowband signals relative to the sampling frequency, at significantly lower oversampling ratios in comparison to the conventional lowpass SD converters. In this paper a sixth-order modulator sampled at 1.82MHz coupled with a multistage polyphase decimation filter is reported for the conversion of bandpass signals centred at 455kHz with 14kHz bandwidth. The decimation filter is using a small number of short-wordlength filter coefficients. The simulations undertaken demonstrated that this setup realises 124.3dB SNR with less than 4mdB passband ripples for a half/full-scale composite 20-sinewave input signal potential of up to 20-bit performance. The resultant converter can directly accomplish demodulation of narrow-band AM signals
abbr_f5377d22982d8ab17b47000deb98ca2e.rar
109.78 KB, 下载次数: 141 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-8-4 11:06:39 | 显示全部楼层
Ding me
发表于 2011-1-19 16:13:23 | 显示全部楼层
fgbdfg
发表于 2011-2-10 14:29:10 | 显示全部楼层
thank you
发表于 2011-4-17 21:50:13 | 显示全部楼层
好东西
发表于 2011-7-25 16:40:55 | 显示全部楼层
thank you very much
发表于 2011-7-25 16:45:16 | 显示全部楼层
thank you very much
发表于 2012-1-7 15:53:37 | 显示全部楼层
haodongxi
发表于 2013-11-18 20:32:57 | 显示全部楼层
发表于 2015-3-7 15:58:25 | 显示全部楼层
GMT+8, 2025-12-30 18:26 , Processed in 0.022062 second(s), 6 queries , Gzip On, Redis On.
