查看: 11533|回复: 23
solution for problems IC5141 in RHEL5
发表于 2010-7-30 12:02:22 | 显示全部楼层 |阅读模式
common problem after install IC5141 in REHL5 OS,
"missing libxx... ..".
This is due to RHEL5 not install all necessary rpm for the IC5141.
Solution: get your RHEL5 DISC and find the following rpm
compat-libf2c-34-3.4.6-4.i386.rpm
compat-libf2c-34-3.4.6-4.x86_64.rpm
compat-libstdc++-296-2.96-138.i386.rpm
compat-libstdc++-33-3.2.3-61.i386.rpm
compat-libstdc++-33-3.2.3-61.x86_64.rpm
libXp-1.0.0-8.1.el5.i386.rpm
libXp-1.0.0-8.1.el5.x86_64.rpm
libXp-devel-1.0.0-8.1.el5.i386.rpm
libXp-devel-1.0.0-8.1.el5.x86_64.rpm
ncompress-4.2.4-47.x86_64.rpm
openmotif22-2.2.3-18.i386.rpm
openmotif22-2.2.3-18.x86_64.rpm
openmotif-2.3.1-2.el5.i386.rpm
openmotif-2.3.1-2.el5.x86_64.rpm
openmotif-devel-2.3.1-2.el5.i386.rpm
openmotif-devel-2.3.1-2.el5.x86_64.rpm
copy those rpm into your system and do the install.
Assume you put those rpm files into /tmp/rpm direcotry. do the install as follows:
  "rpm -i /tmp/rpm/*rpm"
After the rpm installed, you shall not have any problem to use IC5141.
If you have above rpm install, you also shall not have any issue to run any CADENCE or SYNOPSYS tools.
发表于 2010-8-4 09:11:44 | 显示全部楼层
按照楼主的方法,我昨晚上进行了尝试,还是失败啊!
为什么我的icfb不能正常启动啊?
发表于 2010-8-4 12:35:37 | 显示全部楼层
感谢楼主。
发表于 2010-8-4 23:39:28 | 显示全部楼层
发表于 2010-8-4 23:41:04 | 显示全部楼层
发表于 2010-8-6 20:14:10 | 显示全部楼层
没用啊!真的没用啊!
有没有人尝试成功啊?
发表于 2010-8-29 18:35:01 | 显示全部楼层
发表于 2010-8-29 18:46:59 | 显示全部楼层
发表于 2010-8-29 18:50:42 | 显示全部楼层
发表于 2010-8-29 19:10:27 | 显示全部楼层
GMT+8, 2025-12-26 08:31 , Processed in 0.024058 second(s), 5 queries , Gzip On, Redis On.
