查看: 2408|回复: 0
TurboLaunch 5.1.4
发表于 2010-7-14 23:40:52 | 显示全部楼层 |阅读模式
TurboLaunch 5.1.4
Savard Software TurboLaunch v5.1.4
TurboLaunch - The fastest and easiest way to run all of your favorite programs!TurboLaunch is a fully configurable tool-bar style application that can be set up to run many programs and perform certain pre-programmed actions. Like a toolbar, pictures are used to distinguish what a button is configured to do. TurboLaunch automatically uses the default icon, but you have complete control and can change the icon to whatever you want!
TurboLaunch: Key Features:
• Fully configurable buttons provide single-click access to all of your favorite programs. No more navigating through the countless cascading menus in the Start Button!
• The number of rows and columns of buttons can be customized to suit your specific needs.
• Buttons can be organized into groups, and they can be resized for greater visibility or to save valuable screen space.
• Each button can be configured to run any program, document, shortcut, folder, or drive.
• Buttons may be configured to perform certain pre-programmed actions, such as rebooting the system, activating the screen saver, shutting down, and more.
• Network connections (such as the Internet or a VPN connection) can be established and disconnected.
• A Shortcut Key can be assigned to a button for extremely rapid launching with just a quick keyboard command.
• Comprehensive online help and an uninstall option.
Advanced Features:
• Automatic extraction of a program's default icon for use as a picture on the button.
• The icon used as the picture on a button is fully configurable: any icon out of any file may be used!
• Objects such as programs, documents, shortcuts, folders, or drives may be dropped onto any button to quickly configure TurboLaunch.
• Parameters, working folders, window styles, and descriptions are completely configurable.
• 16-bit Windows programs may be run in separate memory spaces for greater multitasking efficiency and crash protection.
• Dynamic Parameter tokens lets you specify all or part of a parameter at the time you click the button.
• "Drop 'n Launch" feature allows you to set up a button so that when a file is dropped on it, the program assigned to that button is started with that file.
• Configuration information is stored in the Registry, allowing each Windows user to have their own TurboLaunch configuration.
• The configuration can be password-protected to keep unauthorized users from making any changes!
• Icon information is automatically cached for rapid starting of TurboLaunch.
• "Roll Up When Not Active" option reduces the size of the TurboLaunch window when it is not active.
• "Prevent Double Runs" option stops accidental double-clicks on buttons from launching the button twice.
• Many, many more options not listed here!
TurboLaunch.5.1.4.rar
1.21 MB, 下载次数: 42 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-10-4 02:29 , Processed in 0.015676 second(s), 6 queries , Gzip On, Redis On.
