查看: 1451|回复: 0
[招聘] NO.152-DIGITAL LAYOUT ENGINEER 3G MULTIMEDIA & PLATFORMS(Shanghai)
发表于 2010-6-29 13:47:24 | 显示全部楼层 |阅读模式
Job Summary The Digital Layout Engineer (DLE) plays an essential role in the physical implementation of the top-level functional netlist, resulting in an optimally placed, routed and verified chip layout. He/she also supports and advises the development team and third parties (subcontractors, customers) with respect to the physical development of Analog & Mixed Signal modules used in the IC’s.
The DLE has sufficient broad knowledge to co-operate with all other competencies within the project, and establishes and contributes to a co-operative and productive interaction in team working situations.
Key Areas of Responsibility 1. Building up, and maintaining knowledge of:
• Schematic, symbol, layout and abstract design, physical topologies and design methodologies.
• Translating IC specifications to an optimal placement of PMU modules and I/O pads, in close co-operation with the system/IC architect and the customer.
• Creating an optimal routing of critical and non-critical signals, supply trunks and clock trees for the complete top-level IC from a functional netlist.
• ESD, EMC, supply strategy, clocking strategy, design for test, and related
2. Layout Verification before Tape Out:
• Verifying and completing the IC with DRC/LVS checks, chip-finishing and bonding.
• Participating in physical design reviews, also in other projects.
• Delivering back-annotated data needed for timing verification of modules, both standalone and embedded in top level circuitry.
• Properly tagging of IC layout data bases
3. Communication:
• Maintain a network of contacts on physical IC design
• Contribute to co-operative and productive team atmosphere
• Communicate with conciseness in both one to one and group situations.
Requirements • BSc-E or MSc-E.
• Being knowledgeable on:
(1) Data exchange formats: LEF, DEF, TLF, (R)SPF, SDF and GDS2.
(2) Synopsys IC compiler
(3) Experience in following tools: Place & Route Tools, Skill, Pearl and other script languages, etc.
• A pro-active attitude.
• Fluent in English
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: winni-cao@kthr.com, thanks!
GMT+8, 2025-12-22 19:58 , Processed in 0.017239 second(s), 6 queries , Gzip On, Redis On.
