楼主: mosou
[求助] 怎么推算出来CRC计算的并行算法
发表于 2013-6-6 10:54:06 | 显示全部楼层
回复 52# lara9554
    你好,你研究CRC并行算法有成果了没呢?
发表于 2013-6-6 11:11:55 | 显示全部楼层
http://www.easics.com/webtools/crctool
Enjoy!
发表于 2013-6-8 18:35:51 | 显示全部楼层
我弄了好几天才弄通,一步一步推,呵呵
发表于 2013-6-28 09:18:02 | 显示全部楼层
感覺很難......應該不適合初學者
发表于 2013-6-28 18:25:36 | 显示全部楼层
这是一个CRC10,数据位宽8,根据easics自动生成的模块修改而成。由于运算复杂度低,整个模块被当作一个只有组合逻辑的黑盒。
在上层模块例化该模块,每个data_in有效的周期,用时钟把crc_out取走更新crc_lst就可以啦
// File:  CRC10_D8.v
// Date:
// Copyright (C) 1999-2003 Easics NV.
// This source file may be used and distributed without restriction
// provided that this copyright statement is not removed from the file
// and that any derivative work contains the original copyright notice
// and the associated disclaimer.
// THIS SOURCE FILE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS
// OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
// WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// Purpose: Verilog module containing a synthesizable CRC function
//   * polynomial: (0 1 4 5 9 10)
//   * data width: 8
// Info: tools@easics.be
//       http://www.easics.com
module CRC10_D8(
                        data_in,
                        crc_lst,
                        crc_out
  // polynomial: (0 1 4 5 9 10)
  // data width: 8
  // convention: the first serial data bit is D[7]
    input [7:0] data_in;
    input [9:0] crc_lst;
    output [9:0] crc_out;
    wire [7:0] D;
    wire [9:0] C;
    wire [9:0] NewCRC;
    assign        D = data_in;
    assign        C = crc_lst;
    assign        NewCRC[0] = D[4] ^ D[3] ^ D[2] ^ D[1] ^ D[0] ^ C[2] ^ C[3] ^ C[4] ^
                C[5] ^ C[6];
    assign        NewCRC[1] = D[5] ^ D[0] ^ C[2] ^ C[7];
    assign        NewCRC[2] = D[6] ^ D[1] ^ C[3] ^ C[8];
    assign        NewCRC[3] = D[7] ^ D[2] ^ C[4] ^ C[9];
    assign        NewCRC[4] = D[4] ^ D[2] ^ D[1] ^ D[0] ^ C[2] ^ C[3] ^ C[4] ^ C[6];
    assign        NewCRC[5] = D[5] ^ D[4] ^ D[0] ^ C[2] ^ C[6] ^ C[7];
    assign        NewCRC[6] = D[6] ^ D[5] ^ D[1] ^ C[3] ^ C[7] ^ C[8];
    assign        NewCRC[7] = D[7] ^ D[6] ^ D[2] ^ C[4] ^ C[8] ^ C[9];
    assign        NewCRC[8] = D[7] ^ D[3] ^ C[0] ^ C[5] ^ C[9];
    assign        NewCRC[9] = D[3] ^ D[2] ^ D[1] ^ D[0] ^ C[1] ^ C[2] ^ C[3] ^ C[4] ^
                C[5];
    assign        crc_out = NewCRC;
endmodule
发表于 2013-8-19 15:54:58 | 显示全部楼层
这篇论文不错啊
发表于 2017-4-19 20:23:40 | 显示全部楼层
谢谢分享
发表于 2017-4-22 19:48:58 | 显示全部楼层
Thanks for the Software Buddy :-)
发表于 2017-4-23 16:33:34 | 显示全部楼层
回复 3# xyflier
   xuexi yixia
发表于 2017-7-14 18:02:47 | 显示全部楼层
恍恍惚惚恍恍惚惚恍恍惚惚
GMT+8, 2025-12-22 19:23 , Processed in 0.023294 second(s), 4 queries , Gzip On, Redis On.
