查看: 11626|回复: 17
ic614 lic still not work
发表于 2010-5-29 20:15:02 | 显示全部楼层 |阅读模式
Hi, all
i've downloaded the ic613 patch from http://www.eetop.cn/bbs/viewthread.php?tid=164488&extra=&highlight=ic6&page=1
but, after patch done, i still can not start up the license file by using lmgrd.
Here's the lmgrd log:
20:01:11 (lmgrd) FLEXnet Licensing (v10.8.6.0 build 54361 i86_re3) started on localhost (linux) (5/29/2010)
20:01:11 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
20:01:11 (lmgrd) US Patents 5,390,297 and 5,671,412.
20:01:11 (lmgrd) World Wide Web:  http://www.macrovision.com
20:01:11 (lmgrd) License file(s): /EDA/license/cadence.lic2
20:01:11 (lmgrd) lmgrd tcp-port 5280
20:01:11 (lmgrd) Starting vendor daemons ...
20:01:11 (lmgrd) Started cdslmd (internet tcp_port 32813 pid 8585)
20:01:11 (cdslmd) FLEXnet Licensing version v10.8.6.0 build 54361 i86_re3
CADENCE_ERROR_MSG:       Invalid license code for FEATURE "100" with code "5D66950377524F5A8349". Ignored.
CADENCE_ERROR_MSG:       Invalid license code for FEATURE "111" with code "5D9685D36F5050568451". Ignored.
CADENCE_ERROR_MSG:       Invalid license code for FEATURE "11400" with code "FDF6F50395CB360670C3". Ignored.
CADENCE_ERROR_MSG:       Invalid license code for FEATURE "12141" with code "0D36F50393CC390074C7". Ignored.
CADENCE_ERROR_MSG:       Invalid license code for FEATURE "12500" with code "FDE6E5B397C7390073C7". Ignored.
Here's the lic file sample:
SERVER localhost ANY 5280
DAEMON cdslmd /EDA/cadence/ic614/tools/bin/cdslmd
FEATURE 100 cdslmd 1000.0000 permanent uncounted 5D66950377524F5A8349 HOSTID=ANY \
        SIGN2=5D66950377524F5A8349
FEATURE 111 cdslmd 1000.0000 permanent uncounted 5D9685D36F5050568451 HOSTID=ANY \
        SIGN2=5D9685D36F5050568451
FEATURE 11400 cdslmd 1000.0000 permanent uncounted FDF6F50395CB360670C3 HOSTID=ANY \
        SIGN2=FDF6F50395CB360670C3
FEATURE 12141 cdslmd 1000.0000 permanent uncounted 0D36F50393CC390074C7 HOSTID=ANY \
        SIGN2=0D36F50393CC390074C7
FEATURE 200 cdslmd 1000.0000 permanent uncounted 5D46951378534F57824C HOSTID=ANY \
        SIGN2=5D46951378534F57824C
FEATURE 206 cdslmd 1000.0000 permanent uncounted 5DA685D3724D5751824C HOSTID=ANY \
        SIGN2=5DA685D3724D5751824C
FEATURE 207 cdslmd 1000.0000 permanent uncounted 5DD695136F4A5F50824C HOSTID=ANY \
        SIGN2=5DD695136F4A5F50824C
FEATURE 21060 cdslmd 1000.0000 permanent uncounted 0D16F5B394C8460171C6 HOSTID=ANY \
        SIGN2=0D16F5B394C8460171C6
FEATURE 21400 cdslmd 1000.0000 permanent uncounted FDD6E59398C4360371C6 HOSTID=ANY \
        SIGN2=FDD6E59398C4360371C6
FEATURE 21900 cdslmd 1000.0000 permanent uncounted EDC6E5F3A9C144FE71C6 HOSTID=ANY \
        SIGN2=EDC6E5F3A9C144FE71C6
FEATURE 21920 cdslmd 1000.0000 permanent uncounted EDC6E5D3A9C144FC71C6 HOSTID=ANY \
        SIGN2=EDC6E5D3A9C144FC71C6
FEATURE 26000 cdslmd 1000.0000 permanent uncounted 0D168563A1CFCB0278BE HOSTID=ANY \
        SIGN2=0D168563A1CFCB0278BE
FEATURE 251 cdslmd 1000.0000 permanent uncounted 5D7675A35C4D3C037FB8 HOSTID=ANY \
What's the problem with the patch?
Can someone provide me the worked patch with IC614.
Thanks
 楼主| 发表于 2010-5-29 20:19:05 | 显示全部楼层
BTW, in order to run skf in my RHEL 4.7, i changed the skf file with this one:
http://www.eetop.cn/bbs/thread-171890-1-2.html
 楼主| 发表于 2010-5-30 08:52:32 | 显示全部楼层
OKay, problem solved~
DO not use lmgrd to startup the floating license.
Use node locked license, and setenv for LM_LICENSE_FILE
发表于 2010-5-31 13:59:27 | 显示全部楼层
不知道啊,来学习的~~~~~~~
发表于 2010-7-4 15:24:16 | 显示全部楼层
use older lmgrd
发表于 2010-7-4 16:30:20 | 显示全部楼层
发表于 2010-8-27 08:18:31 | 显示全部楼层
lz, 请问你是用的610中的lmgrd吗?就做这一点变化,就解决了问题?
发表于 2010-9-9 10:34:50 | 显示全部楼层
some one plz give some details for installing ic614 , i am try from a moth not getting the start , i am using rhle4 as ,
i am not getting following
base install:
- install license server from ic610 or assura314, use the included
  lic-file (gives the well known license error for Capture and
  Cadence_3D_designer) license server must be version 10.8.5 or
  below , 10.8.6 from ic614 does not accept the old license !!
  lmgrd -v prints out the license server version
- install ic614 , skip the license server installation
发表于 2010-10-18 22:36:35 | 显示全部楼层
谢谢分享
发表于 2010-10-18 23:11:08 | 显示全部楼层
thanks
GMT+8, 2025-12-12 04:33 , Processed in 0.020998 second(s), 7 queries , Gzip On, Redis On.
