楼主: ime
ic614 lic still not work
发表于 2011-2-17 11:47:53 | 显示全部楼层
学习了,正准备自己安装。
谢谢
发表于 2011-7-28 10:15:35 | 显示全部楼层
   "DO not use lmgrd to startup the floating license." 这个怎么实现啊?
另外我更新到6.14.005 的时候,就没有地方问我要不要更新SERVER.....什么地方设置这个?
最后,是否可以更新到IC6.14.512 的HOTFIX? 这个PJ还能用吗?
多谢!
发表于 2012-1-11 23:29:02 | 显示全部楼层
thank
发表于 2012-1-19 16:28:28 | 显示全部楼层
回复 3# ime
"OK, problem solved~
Use node locked license, and setenv for LM_LICENSE_FILE"
If you could elaborate on this I would be able to catch up some sleep It may be simple but I do not know how. Could you write down those two lines as examples.
IC614 insisting (without any option during installation) to update license server and at the end nothing works for me even after I patch  -- IC610 works though. How to get around that?  Is there a way to put back license generator to older version? How. Please help.
Thank you in advance.
“好了,问题就迎刃而解了~~
不要使用lmgrd来启动浮动许可证。
使用节点锁定的许可证,并为LM_LICENSE_FILE的setenv“
,如果你能精心在此,我将能够赶上睡觉:)它可能是简单的,但我不知道如何。请问你写下这两条线作为例子。
IC614(在安装过程中没有任何选项)坚持更新许可证服务器,并最终不了了之甚至对我的作品后,我的补丁 - 虽然IC610工程。如何解决?有没有办法把牌照发电机旧版本吗?如何。请帮助。
预先感谢您。
发表于 2012-1-19 16:43:31 | 显示全部楼层
回复 5# EDALORD
use older lmgrd
During installation IC614 insisting (without any option) to update license server. Otherwise it stops without any option kicks out. At the end nothing works for me even after I patch. I have managed to successfully installing  IC610 though. How to get around installing ic614 without updating license server?  Is there a way to put back license generator to older version after everything installed? How. Please explain. I could not figure it out last three weeks and losing a lot of sleep over it. From following this forum I knew you are knowledgeable and managed this task well.
Also I installed MMSIM10.1 but it updated license server even a newer version. I need to set only cdslmd back to lower version without effecting installed software but how?
在安装过程中坚持IC614(不带任何选项)更新许可证服务器。否则,它会停止,不带任何选项踢了。在最后即使我修补后没有我。我已经成功安装IC610虽然管理。如何得到解决的情况下安装更新许可证服务器ic614?有没有办法放回许可发电机旧版本,安装后一切吗?如何。请解释。我不能过去三个星期,失去了很多睡眠。从下面的这个论坛,我知道你有知识和管理任务。
另外,我安装MMSIM10.1但即使是较新的版本更新许可证服务器。我需要设置只cdslmd回低版本,但不会影响已安装的软件,但如何呢?
预先感谢您。
发表于 2013-4-13 01:07:42 | 显示全部楼层
not work...
发表于 2013-4-13 01:13:07 | 显示全部楼层
WOR K PATCH.?
发表于 2013-7-4 22:59:54 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-23 07:08 , Processed in 0.019563 second(s), 4 queries , Gzip On, Redis On.
