查看: 4742|回复: 5
[求助] 综合后出现的警告!!!
发表于 2010-5-21 10:06:14 | 显示全部楼层 |阅读模式
WARNING:Xst:37 - Detected unknown constraint/property "BLACK_BOX". This constraint/property is not supported by the current software release and will be ignored.
WARNING:Xst:1814 - Core <sqrt.ngc> does not contain any logic.
WARNING:Xst:2036 - Inserting OBUF on port <dataout_1<7>> driven by black box <sqrt>. Possible simulation mismatch.
WARNING:Xst:2036 - Inserting OBUF on port <dataout_1<6>> driven by black box <sqrt>. Possible simulation mismatch.
WARNING:Xst:2036 - Inserting OBUF on port <dataout_1<5>> driven by black box <sqrt>. Possible simulation mismatch.
WARNING:Xst:2036 - Inserting OBUF on port <dataout_1<4>> driven by black box <sqrt>. Possible simulation mismatch.
WARNING:Xst:2036 - Inserting OBUF on port <dataout_1<3>> driven by black box <sqrt>. Possible simulation mismatch.
WARNING:Xst:2036 - Inserting OBUF on port <dataout_1<2>> driven by black box <sqrt>. Possible simulation mismatch.
WARNING:Xst:2036 - Inserting OBUF on port <dataout_1<1>> driven by black box <sqrt>. Possible simulation mismatch.
WARNING:Xst:2036 - Inserting OBUF on port <dataout_1<0>> driven by black box <sqrt>. Possible simulation mismatch.
WARNING:Xst:616 - Invalid property "BLACK_BOX 1": Did not attach to sqrt_1.
出现了这么多的警告 然后用modelsim进行前仿真的时候 输出为高阻
求救
 楼主| 发表于 2010-5-21 10:07:21 | 显示全部楼层
调用的是cordic的IP核
发表于 2010-5-21 13:05:04 | 显示全部楼层
看说明好像是说你的软件对ngc的仿真不支持
发表于 2010-5-21 13:41:43 | 显示全部楼层
产生sqrt.ngc时不要OBUF,综合可以设置不带OBUF
 楼主| 发表于 2010-5-21 14:48:53 | 显示全部楼层
 楼主| 发表于 2010-5-21 16:50:50 | 显示全部楼层
这个问题已经解决是ISE版本的问题
我换成ise11.1之后就好了
谢谢大家了
GMT+8, 2025-12-15 20:00 , Processed in 0.372270 second(s), 6 queries , Gzip On, Redis On.
