查看: 2137|回复: 1
[招聘] NO.125-Senior Physical Implementation engineers(Shanghai、Xi’an)
发表于 2010-5-17 17:37:14 | 显示全部楼层 |阅读模式
Experience
5+ years in physical implementation engineering
Essential skills
The successful applicants will need experience in at least some of the following areas:
• Digital Soc chip design and implementation
• Design automation and analysis using scripting languages, particular Tcl and Perl
• Design Flows and the EDA tools, in particular tools from Magma, Mentor and Synopsys. Experience with tools from Apache and Azuro would be an advantage
• Sign-off methodology and EDA tools for STA, Noise, Power, etc.
• Structured design styles involving placed gates
• ATPG tools and methodologies.
Key Responsibilities
Depending on experience, key responsibilities will involve some of the following:
• Development and optimisation of high performance and low power Soc physical implementation methodology
• Working with European engineers to do block level and full chip floor planning, timing and power analysis, and P&R
• Design consulting in customer’s offices on physical implementation tasks
• Interfacing with foundry and IP providers on IP imports and test definition.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: winni-caor@kthr.com, thanks!
发表于 2010-5-19 18:16:03 | 显示全部楼层
帮楼主顶顶
GMT+8, 2025-12-23 05:16 , Processed in 0.012205 second(s), 3 queries , Gzip On, Redis On.
