查看: 8671|回复: 25
[资料] Fully differential telescope opamp design for 10b_40M adc
发表于 2010-5-14 20:00:54 | 显示全部楼层 |阅读模式
发一个
Fully differential telescope opamp design.pdf
492.02 KB, 下载次数: 252 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-5-16 02:42:00 | 显示全部楼层
thank you...
发表于 2010-5-16 04:10:14 | 显示全部楼层
thanks for sharing this document, take care!
发表于 2010-5-28 03:44:57 | 显示全部楼层
14 页
Fully-differential telescopic op-amp design
1 OPAMP specification define
The op-amp is used in stage3 of a 10bit 40Mhz 20mW pipelined ADC. The detail
specification of the op-amp must meet the requirement of corresponding stage. The following is
the derivation of the specifications of op-amps in respective stages and the design work is foxed
on the stage3 and stage4 op-amp.
The 10-bit 40Msps pipelined ADC adopted 2.5bit/stage structure. It includes 4 stages and a
2-bits flash ADC as the last stage. THA is eliminated because of low power consideration. The
whole power dissipation is 20mW, and a lot of efforts are foxed on the low power op-amp design.
1.1 DC gain requirement
发表于 2010-5-30 14:39:31 | 显示全部楼层
thank you...
发表于 2010-5-30 14:42:38 | 显示全部楼层
thank you...
发表于 2010-5-30 15:25:43 | 显示全部楼层
dddddddd
发表于 2010-5-30 19:07:17 | 显示全部楼层
good!
发表于 2010-7-15 23:03:35 | 显示全部楼层
谢谢了
发表于 2010-7-25 22:01:36 | 显示全部楼层
学习一下,收下了谢谢
GMT+8, 2025-12-9 20:31 , Processed in 0.034052 second(s), 9 queries , Gzip On, Redis On.
