查看: 20637|回复: 62
[资料] 来自于OPENCORE的Verilog语言的embedded_risc软核
发表于 2010-5-11 09:41:10 | 显示全部楼层 |阅读模式
SOC设计,包含比较多的内容。可以作为学习参考代码。比较有价值
顶层文件描述:
MODULE:  Top Level System On A Chip Design
FILE NAME: soc.v
DATE:  May 7th, 2002
AUTHOR:  Hossein Amidi
COMPANY:
CODE TYPE: Register Transfer Level
DESCRIPTION: This module is the top level RTL code of System On a Chip Verilog code.
It will instantiate the following blocks in the ASIC:
1)   Vertex STARTUP
2) DLL
3) RISC uProcessor
4) DMA Cntrl
5) LRU Data Cache
6) LRU Instruction Cache
7) Bus Arbiter
8) UART
9) Timer
10)  Flash Controller
11) SDRAM Controller
Hossein Amidi
(C) May 2002
embedded_risc_latest.tar.gz
2.06 MB, 下载次数: 649 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-5-11 09:45:32 | 显示全部楼层
module soc(        // Inputs
                                                clk,
                                                reset,
                                                irq,
                                                ser_rxd,
                                                flash_datain,
                                                mem_datain,
                                                // Outputs
                                                pll_lock,
                                                addr,
                                                cs,
                                                ras,
                                                cas,
                                                we,
                                                dqm,
                                                cke,
                                                ba,
                                                pllclk,
                                                halted,
                                                ser_txd,
                                                flash_cle,
                                                flash_ale,
                                                flash_ce,
                                                flash_re,
                                                flash_we,
                                                flash_wp,
                                                flash_rb,
                                                flash_irq,
                                                flash_dataout,
                                                mem_dataout,
                                                mem_addr,
                                                mem_req,
                                                mem_rdwr,
                                                // Inouts
                                                dq
 楼主| 发表于 2010-5-11 09:47:00 | 显示全部楼层
bus_arbiter  bus_arbiter0(        // Input
        .reset(reset),
        .clk0(clk0),
        .bus_request(bus_request),
        .dma_dataout(dma_wr_dataout),
        .dma_addr(dma_rd_addr),
        .dma_cmd(dma_rd_cmd),
        .dcache_dataout(dcache_dataout),
        .dcache_addr(dcache_addr),
        .dcache_cmd(dcache_cmd),
        .icache_dataout(icache_dataout),
        .icache_addr(icache_addr),
        .icache_cmd(icache_cmd),
        .sdram_dataout(sdram_dataout),
        // Output
        .bus_grant(bus_grant),
        .dma_datain(dma_wr_datain),
        .dcache_datain(dcache_datain),
        .icache_datain(icache_datain),
        .sdram_addr(sdram_addr),
        .sdram_cmd(sdram_cmd),
        .sdram_datain(sdram_datain)
uart  uart0(// Input
                                .reset(reset),
                                .clk0(clk0),
                                .uart_addr(dma_wr_addr),
                                .uart_host_addr(host_addr),
                                .uart_host_cmd(host_cmd),
                                .uart_cmd(dma_rd_cmd),
                                .uart_host_datain(uart_host_dataout),
                                .uart_cs(uart_cs),
                                .uart_rd(uart_rd),
                                .uart_wr(uart_wr),
                                .ser_rxd(ser_rxd),
                                .uart_datain(dma_rd_dataout),
                                // Output
                                .ser_txd(ser_txd),
                                .uart_host_dataout(uart_host_datain),
                                .uart_dataout(dma_rd_datain)
timer         timer0(        // Input
                                                .reset(reset),
                                                .clk0(clk0),
                                                .timer_host_datain(timer_host_dataout),
                                                .timer_cmd(host_cmd),
                                                .timer_addr(host_addr),
                                                // Output
                                                .timer_host_dataout(timer_host_datain),
                                                .timer_irq(timer_irq)
flash_ctrl flash_ctrl0(// Inputs
        .reset(reset),
        .clk0(clk0),
        .flash_host_addr(host_addr),
        .flash_host_cmd(host_cmd),
        .flash_host_dataout(flash_host_dataout),
        .flash_datain(flash_datain),
        // Outputs
        .flash_host_datain(flash_host_datain),
        .flash_cle(flash_cle),
        .flash_ale(flash_ale),
        .flash_ce(flash_ce),
        .flash_re(flash_re),
        .flash_we(flash_we),
        .flash_wp(flash_wp),
        .flash_rb(flash_rb),
        .flash_irq(flash_irq),
        .flash_dataout(flash_dataout)
sdram_ctrl sdram_ctrl0(// Inputs
        .clk0(clk0),
        .clk0_2x(clk0_2x),
        .reset(reset),
        .paddr(sdram_addr),
        .cmd(sdram_cmd),
        .dm(host_dm),
        .datain(sdram_datain),
        // Outputs
        .cmdack(cmdack),
        .addr(addr),
        .cs(cs),
        .ras(ras),
        .cas(cas),
        .we(we),
        .dqm(dqm),
        .cke(cke),
        .ba(ba),
        .dataout(sdram_dataout),
        // Inouts
        .dq(dq)
发表于 2010-5-12 09:47:51 | 显示全部楼层
好东东 謝謝分享了。
发表于 2010-5-12 10:14:52 | 显示全部楼层
thank you ~
发表于 2010-5-14 09:24:46 | 显示全部楼层
謝謝分享
发表于 2010-6-4 14:14:48 | 显示全部楼层
V 非常感谢!!!!!!!!11
发表于 2010-6-26 19:00:29 | 显示全部楼层
非常感谢!!!!!!!!11
发表于 2010-6-27 17:01:04 | 显示全部楼层
去opencore上下好了啊。。。
发表于 2010-7-10 13:05:16 | 显示全部楼层
看看,呵呵!
GMT+8, 2025-9-15 07:04 , Processed in 0.023928 second(s), 6 queries , Gzip On, Redis On.
