查看: 4678|回复: 3
[求助] 请问astro中LEQ以及ECO分别是什么意思??
发表于 2010-5-6 11:24:25 | 显示全部楼层 |阅读模式
没找到全称,还望大侠指点一下
发表于 2010-5-6 16:00:26 | 显示全部楼层
eco=engineering change order
leq,不知道。。。。
发表于 2010-5-11 20:05:23 | 显示全部楼层
LEQ=Logic Equivalence
发表于 2012-3-15 15:00:09 | 显示全部楼层
“ECO” is an old term which stands for “engineering change order”. In the early days of circuit
design, if a change needed to be made to a part of the design that was already defined or specified,
you would fill out an “Engineering Change Order” form and have it signed off before making the
change. Even though most companies no longer use ECO forms, the term is still used, and refers to
design changes late, or near the end of the design phase.
GMT+8, 2025-12-15 15:25 , Processed in 0.024058 second(s), 8 queries , Gzip On, Redis On.
