楼主: SamsungMonitor
Cadence SOC Encounter 8.1 - USR3
发表于 2010-7-14 00:34:49 | 显示全部楼层
dddddddddddddddd
头像被屏蔽
发表于 2010-7-15 02:29:26 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-7-17 04:33:43 | 显示全部楼层
Hi,I spent all of my money to download this soft.thanks.
I have problem when I installed it.yhe system always ask for let specify Release Disk 1.
Do you know why?thanks in advance
 楼主| 发表于 2010-7-17 08:14:46 | 显示全部楼层
111qqq 发表于 2010-7-17 04:33
Extract all 4 CD into the same directory. Install as usual using installscape.
Please let me know if your problems still cannot solve.
发表于 2010-7-17 16:13:24 | 显示全部楼层
Hi ,
I'm not sure what you mean exactly "Extract all 4 CD into the same directory"
because they have the same directory "SOC08.10.003_lnx86.Update\CDROM1\kits"
how can I extract them into the same directory?or into which directory?
I'm sorry that I have many quextions about this.
 楼主| 发表于 2010-7-17 16:43:48 | 显示全部楼层
Hi ,
111qqq 发表于 2010-7-17 16:13
Yes. You do the correct things. Just ignore what I said at above.
Can you take some screenshot about the errors.
Thanks.
发表于 2010-7-17 19:10:49 | 显示全部楼层
soc.JPG Hi, I describe what I did as below,it's little bit complex. 1.I copy the files into the same directory and burned into one DVD. The files which are from Disk 1 under \SOC08.10.003_lnx86.Update\CDROM1 and Disk 2 ,3 ,4, under \SOC08.10.003_lnx86.Update\CDROM1\kits 2.then I executed iscape.sh, a.select source directory --->ok. b.select products --->ok c.select install directory --->ok d.then ...
发表于 2010-7-17 19:12:32 | 显示全部楼层
btw,I use VMware.Thanks
 楼主| 发表于 2010-7-17 23:19:47 | 显示全部楼层
68# 111qqq
When you extract the SOC08.10.003_lnx86.Update, the total size is 2.00GB.
There are only 166 items without any folder under directory \SOC08.10.003_lnx86.Update\CDROM1\kits.
发表于 2010-7-18 04:24:53 | 显示全部楼层
Hi,
The files amounts is correct and there is no other folder under kits\.
whatever,I gave up to install it.
many thanks for your patience.
GMT+8, 2025-12-18 19:58 , Processed in 0.022392 second(s), 5 queries , Gzip On, Redis On.
