楼主: SamsungMonitor
Cadence SOC Encounter 8.1 - USR3
 楼主| 发表于 2010-7-18 08:18:42 | 显示全部楼层
I test again with the installer, but I didn't face the problems.
I think maybe there is some minor errors during you burn it into DVD.
BTW, since you use the VMWare, you can direct install it by access the softcopy of SOC81_Update.
发表于 2010-7-18 15:39:22 | 显示全部楼层
Thanks
发表于 2010-7-18 18:39:04 | 显示全部楼层
Hi,SamsungMonitor
It's working,I don't know what happen before...
now,there is another question.
how can I setup the cshrc for soc?
I've installed cadence IC610.
thanks.
发表于 2010-7-18 20:01:01 | 显示全部楼层
when I executed the encounter,the windows appear then I can't see anything in edit area. soc.JPG
发表于 2010-7-18 20:02:37 | 显示全部楼层
what is the lowest system request of soc?
发表于 2010-7-18 22:11:06 | 显示全部楼层
I think what the problem is.
I execute on the background,maybe it causes the problem...
but environment setup still need to be solved.
 楼主| 发表于 2010-7-18 22:13:54 | 显示全部楼层
111qqq 发表于 2010-7-18 22:11
I don't have that problems.
发表于 2010-7-20 13:14:37 | 显示全部楼层
looklook
发表于 2010-7-21 19:40:39 | 显示全部楼层
发表于 2010-7-22 12:31:13 | 显示全部楼层
学习学习,看样子是个好东西
GMT+8, 2025-12-29 16:42 , Processed in 0.159651 second(s), 5 queries , Gzip On, Redis On.
