查看: 6130|回复: 8
[招聘] AMD最新招聘职位-内部推荐
发表于 2010-4-27 21:08:44 | 显示全部楼层 |阅读模式
本人为AMD员工,职位是ASIC设计验证,有找工作或想跳槽的朋友可以把你们的简历发到我的邮箱
邮箱1:liujing_821@hotmail.com;
邮箱2:Jane2.Jin@amd.com
两个都发一下,以便能及时收到。
以下是最新的招聘职位和需求:
有 ASIC design 和验证, software 和 hardware, FAE QA test等职位
Title: MTS/SMTS Electrical Analysis and Debug Location: Shanghai #1
 JOB DESCRIPTION:
Processor silicon DDR interface electrical test and debug engineer in the Shan
ghai Research & Development Design Center. In this role, this senior level eng
ineer will be part of a highly technical team that develops test plans, execut
es bring-up & test plans, & debugs electrical issues in the memory sub-system
of new processors. The job entails extensive hands-on lab work as well as tech
nical leadership and communication across teams.
 SPECIFIC JOB FUNCTIONS:
1) Provides DDR technical leadership in the development of new test & validati
on features
2) Closely interacts with silicon design (DRAM controller and phy) in test exe
cution & debug, as well as in feature definition for future product generation
3) Writes comprehensive electrical & functional test plans for the memory vali
dation of processors
4) Executes electrical & functional test plans for AMD processors using hardwa
re & software validation tools, oscilloscopes, & logic analyzers. 5) Debug of
electrical & functional issues of the memory sub-system of new processors
6) Provides detailed input into the platform definition & review of platform d
esigns used in the silicon validation of new processors. 7) Provides technical
guidance and training to less experienced engineers and technicians in the pl
anning, test, & debug of the memory sub-system.
 SKILLS REQUIRED:
1) BS-EE / BS-CE with at least 10 years directly related experience. An advanc
ed degree will be considered a plus. 2) Requires experience and demonstrated t
echnical expertise in the development & execution of platform level electrical
& functional test plans. DDR2/3 Memory test experience on electronic componen
ts such as Processors would be considered a big plus. 3) Requires extensive ha
nds-on experience and demonstrated technical expertise in the debug of I/O int
erfaces such as DDR 4) Demonstrated experience with or knowledge using oscillo
scopes, reading schematics and layout documentation
5) Requires good written and oral communication skills.
6) Demonstrated ability to communicate with a variety of engineering disciplin
es and management.
https://amd.apply2jobs.com/index.cfm?fuseaction=mExternal.showJob&RID=9593&Cur
rentPage=1
Title: SMTS/MTS for Hardware/Platform Design Engineer Location: Shanghai #1
 JOB DESCRIPTION:
Technical leader responsible for graphic, motherboard, and system design in ou
r Shanghai Research and Development Center (SRDC). Systems are integrated comb
inations of hardware components (CPUs, graphics, memory, IO adapters, peripher
als, and BMCs) and software components (firmware, drivers, OS, virtualization,
and system management). This individual will interface with the Marketing, Si
licon design, Software, and Validation teams to define our platforms for new s
ilicon, provide detailed technical direction to the SRDC engineers to draw sch
ematics, layout the board, develop the System BOM, bring up, debug issues, and
complete Motherboard QA testing.
1) Motherboard and system specification, negotiate features with input teams a
nd silicon designers
2) Schematic capture and guide layout of motherboards for new silicon
3) Feedback and refine design rules with simulation and silicon design teams
4) Bring up and validate motherboard and systems
5) Negotiate solid solutions to technical issues and design challenges
6) Ensure all processes are met in development
7) Contribute to client system development processes, team development, tool d
evelopment
8) Support silicon validation, characterization, and debug of existing and new
microprocessor and chip-set products
9) Project planning, status tracking, and reporting to senior management
 SKILLS REQUIRED:
1) Excellent communication skills
2) Prior experience with software testing tools and environments, defect track
ing, and revision control
3) Familiar with Microsoft Client Operating Systems, Linux Operating Systems,
virtualization software (VMware, Xen, et al), and validation/certification pro
cesses for each of these environments
4) Familiar with client system component compatibility and stress testing
5) Familiar with high performance client IO adapters, drivers, and stress test
ing
6) Familiar with general Computer Architecture concepts
7) Skilled in Cadence Concept schematic capture
 SKILLS PREFERRED:
1) Familiar with Cadence Allegro layout tools
2) Familiar with MS Office & MS Project tool suites
3) Familiar with microprocessor bring-up and debug
4) Familiar with C/C++, JAVA, and scripting language programming
 PREFERRED EDUCATION AND EXPERIENCE:
A Bachelor's and/or Master's degree in Computer Science or Computer Engineerin
g. Requires 10-20 years experience leading computer system development.
https://amd.apply2jobs.com/index.cfm?fuseaction=mExternal.showJob&RID=9595&Cur
rentPage=1
Title: MTS-SMTS Thermal Mechanical Engineer Location: Shanghai #1
 JOB DESCRIPTION:
This position will be responsible for thermal and mechanical engineering in su
pport and development of discrete graphics, graphics cards, CPUs, and chipsets
in AMD Shanghai Research and Development Center (SRDC). The position is for a
n experienced engineer that will perform hands-on engineering with local board
engineering teams in SRDC, suppliers/partners in the thermal management field
in the Far East, and interface with other AMD engineering and development org
anizations in various locations – Toronto, Canada; Austin, Texas, Sunnyvale,
CA, Singapore, and others.
This position will entail experimental thermal/fluid mechanics work directed a
t the development of thermal solutions, mechanical design of components and sy
stems, and/or numerical analysis of thermal/fluids or mechanical aspects. Good
lab skills, experience with data acquisition using Lab View, and general heat
transfer and fluid mechanics skills are required. Experience in cross functio
nal leadership roles or technical management/project leadership is required. C
reation and maintenance of keep out, part and assembly drawings will also be r
equired. Experience with Pro/E and Solid Works is required. Experience with Fl
otherm, Icepak, or ANSYS is a plus. This specific candidate will also support
critical customers in thermal and mechanical area when designing with AMD prod
ucts. Candidates with experience in a combination of these skills are encourag
ed to apply.
 COMMUNICATION SKILLS:
Due to the breadth and interactions of this position, good communication skill
, in spoken and written English, are required.
Mechanical Engineering Graduate with BSME minimum, MSME preferred with 7-10 ye
ars of experience at computer or Semiconductor Company in thermal and mechanic
al engineering.
https://amd.apply2jobs.com/index.cfm?fuseaction=mExternal.showJob&RID=9625&Cur
rentPage=1
Title: PMTS Systems Debug Engineer Location: Shanghai #1
 JOB DESCRIPTION:
Build and provide technical leadership and direction to the system debug team.
Systems debug team is responsible for analysis and resolution of AMD silicon
and system issues which are on AMD reference platform designs and customer dev
elopment stage PC systems across a broad range of market segments using oscill
oscopes, logic analyzers and software/hardware debug tools in an intense but r
ewarding environment
This person is responsible for establishing and maintaining AMD’s technologic
al leadership position in Systems Debug domain. The individual will be respons
ible for projects and processes of significant strategic or commercial importa
nce and for project/program results. He/she needs to be able to strategize and
provide long term planning in technical as well as managerial. This individua
l should be able to coach/mentor experienced staff and provide consultative di
rection to Senior management. The individual will pioneer hardware/software de
sign improvements to internal and external designs and will provide solutions
to external and internal customers. Define innovative test fixtures, experimen
ts, diagnostics and analysis procedures as needed. The successful candidate mu
st have an intimate knowledge of PC architecture and PC system busses and be a
highly motivated, innovative individual with a keen interest in finding and r
esolving silicon and platform failures.
A technology related bachelor's degree or equivalent combination of training p
lus 9 years (or Masters with 7 years) lead-engineer experience in a computer s
ystem development and/or debug environment. Requires a good understanding of a
ll PC HW and SW ( BIOS / Driver ) elements and knowledge of PC system architec
ture. Must be proficient in x86 32-bit protected mode assembly language. Requi
res effective communications and human relation skills. In depth experience w/
Hypertransport bus, DDR2 memory and/or PC I/O busses and the ability to rapid
ly learn new ones is preferred. Experience with micro-architecture and debug o
f AMD chipsets and/or CPUs would be a plus. Publications/patents in the system
design/debug and participation in industry wide forums are preferred.
https://amd.apply2jobs.com/index.cfm?fuseaction=mExternal.showJob&RID=9978&Cur
rentPage=1
Title: MTS/Sr. Design Verification Engineer Location: Shanghai #2
 PREFERRED EXPERIENCE :
The successful candidate will have an MSEE,BSEE or equivalent degree, must hav
e minimum of 3 years of ASIC design verification experience. The candidate sho
uld have knowledge of design verification methodologies. Must be similiar with
SATA/SAS . The experinece on shell/perl/Makefile programming in linux OS is p
lus. Experience with Verilog design/simulation and SystemC/C++ programming is
necessary. Experiences with Hardware assertion languages such as PSL/SVA, and
the Experiences of testbench creation and functional coverage with HDL's such
as System Verilog or SystemC is a plus. The candidate must exhibit good verbal
and written communication skills in both Chinese and English.
 DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION :
The AMD South Bridges Group has openings for a MTS/Sr. Design Verification Eng
ineer. The successful candidate will apply current functional verification tec
hniques to perform and improve pre-silicon verification quality and product Ti
me to Market for Southbridge design. He/She should be able to work independent
ly on various DV tasks and providing technical guidences to the DV team. The c
andidate would involve technically in the porting/creation of the DV environme
nt for the new design, block and chip level testplan creation and implementati
on, coverage analysis, and regression cleanup.
Title: MTS. ASIC CAD engineer Location: Shanghai #5
 JOB DESCRIPTION:
1) Participate in the design and implementation of the leading edge, front-to-
back ASIC design flow which covers logical and physical implementation and ana
lysis of complex devices that integrate multiple cores and IP’s from organiza
tions with AMD global teams.
2) Participate in the research of Design Methodology to improve automation and
productivity to produce AMD's new high-quality cutting-edge graphics processi
ng products
3) Technical support and programming
4) Interface with EDA venders on technology
1) major in EE, CS or related, Master Degree with 5+ years or Bachelor with 7+
years working experiences
2) good programming skill with one or more languages (e.g. tcl, perl , python,
c/c++, etc) in unix/linux and a strong desire to automate flow
3) experience in ASIC design (digital design, Front-end or Back-end)
4) familiar with one or more ASIC flows (logic synthesis, STA, formality check
, Design for Power, place & route, signal integrity analysis, CTS design, desi
gn rule and connectivity verification, DFT ) and usage of related EDA tools
5) Good written and spoken English
6) Good communication skills and be able to work both independently and in a t
eam
Position: Senior IC Engineer
Responsibilities:
-        Independently handle key IC design tasks:
        Block level Micro-architecture, RTL Design, Verification, Synthesis a
nd timing closure.
        Top level integration, including clock/reset implementation, synthesi
s and timing closure.
        FPGA validation and Silicon bring-up.
-        Participating in company’s key engineering initiatives: Methodology improve
ment, new architecture study and proposal.
-        Coordinating joint development with 3rd party:
        IP selection/management and vendor coordination
        Interface with 3rd party vendor for successful execution
Requirements:
Must have:
- BSEE Degree or equivalent
- 3-5 years of experience in hands-on IC design
- Familiarity with ASIC design methodology and SoC architecture.
- Familiarity with standard CAD tools including simulation, synthesis, formal
verification tools.
- Self-motivated in solving problems
- Good communication skills and fluent in English.
- Good team player.
A plus to have:
-        Good scripting skills.
-        DDR design experience.
-        Experience in DFT.
发表于 2010-4-27 22:48:17 | 显示全部楼层
ddddddddddddddddddddddd
发表于 2010-4-27 22:51:29 | 显示全部楼层
 楼主| 发表于 2010-4-28 13:48:52 | 显示全部楼层
Title:                        Board Program Manager
Job Description:
- Manage the Design and Delivery of Desktop Board Projects.
- To catalyze efficient & speedy program execution and through leadership, effective communication, organization, and planning.
- Manage technical issues, expectations and risk both within the Program Team and with Internal Customers to ensure products meet their market window within acceptable quality targets.
- Manage the sampling process for both internal engineering teams and Customers.
- Oversee material sourcing, particularly for long-lead components
- Drive & track Desktop Board Product schedules
- Oversee the Desktop Board Development Process to ensure all requirements are met;
- Provide business insight as it pertains to Board designs, and work effectively with vendors and partners
- Provide concise updates to executive teams on plans, status and risk mitigation
- Drive process improvements initiatives in order to improve overall execution of programs;
Job requirements
- Electrical Engineering Degree (or equivalent)
- PMP Designation an asset;
- Must have good communication skills and the ability and desire to work as a team;
- Presentation Skills;
- Leadership Skills;
- Organization/Planning Skills;
- Knowledge of MS Project;
- Experience with cross-functional Teams;
- Experience with Electronics or Board Products;
https://amd.apply2jobs.com/index ... 4&CurrentPage=1
Title:                        MTS/SMTS Thermal / Mechanical Design Engineer
Job Description:
This position will be responsible for thermal and mechanical engineering in support and development of discrete graphics, graphics cards, CPUs, and chipsets in AMD Shanghai Research and Development Center (SRDC). The position is for an experienced engineer that will perform hands-on engineering with local board engineering teams in SRDC, suppliers/partners in the thermal management field in the Far East, and interface with other AMD engineering and development organizations in various locations – Toronto, Canada; Austin, Texas, Sunnyvale , CA, Singapore, and others.
Job Requirements:
SPECIFIC JOB FUNCTIONS: This position will entail experimental thermal/fluid mechanics work directed at the development of thermal solutions, mechanical design of components and systems, and/or numerical analysis of thermal/fluids or mechanical aspects. Good lab skills, experience with data acquisition using Lab View, and general heat transfer and fluid mechanics skills are required. Experience in cross functional leadership roles or technical management/project leadership is required. Creation and maintenance of keepout, part and assembly drawings will also be required. Experience with Pro/E and SolidWorks is required. Experience with Flotherm , Icepak, or ANSYS is a plus. This specific candidate will also support critical customers in thermal and mechanical area when designing with AMD products. Candidates with experience in a combination of these skills are encouraged to apply.
COMMUNICATION SKILLS: Due to the breadth and interactions of this position, good communication skill, in spoken and written English, are required.
PREFERRED EDUCATION AND EXPERIENCE: Mechanical Engineering Graduate with BSME minimum, MSME preferred with 7-10 years of experience at computer or semiconductor company in thermal and mechanical engineering
https://amd.apply2jobs.com/index ... 5&CurrentPage=2
Title:                                Section Manager, Diagnostics development
KEY RESPONSIBILITIES
• Manage a team who are responsible for diagnostics development, production diagnostics release, customers support for AMD graphics products
• Start build up the team in SRDC that will work closely with the teams in Markham
• Hiring new team members to expand the teams capabilities to meet the challenges of a growing market.
• Analyze graphic board hardware designs and architect comprehensive test strategies and implement test suites
• Work with diagnostic team members, design and develop diagnostics software for next-generation product
• Participate in board and system bring up
• Identifying and helping resolve hardware and diagnostic issues
• Provide diagnostics support for customers and Hardware teams
• Provide technical direction, mentoring, and skill development as well as regular performance reviews for the team members.
• Forward thinker to improve development process and drive innovation
• Provide leadership and direction in crisis
• Responsible for execution of programs. Multiple projects on the go
REQUIREMENTS
• B.Sc. or M.Sc. In EE or CS or equivalent is required
• Good English required – verbal and written
• Mandarin
EXPERIENCE AND SKILLS
• 4+ years of experience managing a diagnostics design team.
• A minimum of 3+ years experience on driver or embedded SW development and closely interact with HW designer (5+ years as a bachelor, 3+ years as a master)
• Hands on diagnostics development for an ASIC company is preferred
• Prior experience in a direct OEM customer interface role is preferred
• Experience in video capture and tuner technology highly desired
• Strong mix of large-scale software development ability and hardware understanding
• Proficient in C programming language
• Hands-on experience with any one of display interface, PCI-E, and GDDR memories is preferred.
• Hands-on experience with 3D graphics is highly desired
• Strong experience with board bring up is essential
• Familiar with Linux
• Strong debugging and testing skills
• Strong communication skills
• Program management experience to handle multiple projects
https://amd.apply2jobs.com/index ... 6&CurrentPage=1
Title:                        Manager, PCB Layout
• Manage a team who are responsible for AMD graphics and CPU client motherboard PCB layout design, global library management, new technology development
• Work and communicate with counterpart teams in NA to deliver successful PCB layout design
REQUIREMENTS
• Mandarin
• 4+ years of proven experience managing a PCB layout team
• A minimum of 5+ years hands on experience for PC/server motherboard or graphics board PCB layout design(5+ years as a bachelor, 3+ years as a master)
• Skillful to operate Cadence Allegro, Concept, ProE along with strong skills in designing high speed, multi layer, high density designs, Analog/RF layout and power supply layout.
• Hands on experience to create and manage PCB library
• Highly self-motivated and a self starter and have good communications skills.
• Good knowledge of IPC specifications, PCB manufacturing and assembly process
https://amd.apply2jobs.com/index ... 7&CurrentPage=1
Title:                                        Sr. Engineer, Diagnostics Development
Location:                                        Shanghai
• Analyze graphics board hardware designs and architect comprehensive test strategies and implement test suites
• Design and develop diagnostics software for next-generation products
• Production diagnostics release
• Provide diagnostics support for customers and board design teams
REQUIREMENTS
• Mandarin
• A minimum of 6+ years experience on driver or embedded SW development and closely interact with HW designers (6+ years as a bachelor, 4+ years as a master)
https://amd.apply2jobs.com/index ... 8&CurrentPage=1
Title:                        Sr. Memory Tuning Engineer
Graphics Platform Engineering Team has immediate opening for a Sr. memory tuning engineer to provide continuous support to AMD design engineers in testing and qualification of graphics memories specific to AMD Graphics Cards and provide first hand engineering support to AIB and ODM customers in memory tuning, troubleshooting and failure analysis. Key responsibilities of the position was listed as below
• Work with Manager, MTAG to support the qualification of memories on AMD graphics products.
• Develop and perform BIOS tuning and verify memory interface to test memories on various AMD boards.
• Qualify alternate memory sources for AMD OEM, ODM and AIB customers.
• Troubleshoot and provide solutions and perform FAs for problems related to functionality of memories on AMD boards.
• Perform Signal Integrity measurements as requested by OEM/ODM customers.
• Develop and improve memory test methodologies and procedures as the new memory technologies emerge.
• Assist in joint qualifications with memory suppliers for new die memories or new devices from new suppliers.
• Assist Field Application Engineers to support AMD customers in BIOS tuning and other memory related issues.
• Generate memory qualification reports and maintain memory AVLs.
REQUIREMENTS
• Mandarin
• At least 6+ years experience in electronic hardware development or test environment (6+ years as a bachelor, 4+ years as a master)
• Understand high-speed mix-signal multi-layer PCB design techniques
• Experience with DRAM memories and knowledge of different memory technologies is an asset.
• Skilful to operate high bandwidth oscilloscope for high speed signal measuring and analyzing
• Good communication skills and tact in order to set up liaison with customers and memory vendors and internal AMD departments.
• Knowledge of PC, CPU and graphics architectures
• Proven ability to effectively handle fast-pace projects
• Must be a self-motivated contributor and a strong team player
• Effective communication skills (both written and spoken) in English and Mandarin
https://amd.apply2jobs.com/index ... 9&CurrentPage=1
Title:                                Sr. Power Design Engineer
Your responsibility is to drive voltage regulator (including and not limited to LDOs, VRDs, DC-DC SMPS, etc) development from inception to product launch, and to support board designs through silicon improvements, performance/cost analysis, PCB layout, product bring-up, qualification, reliability/safety testing, manufacturability analysis and volume production. In this position you will work in a dynamic engineering environment participating in a wide variety of challenging projects, transform ideas from the drawing board into commercial successes for the company, and be part of a product development team that launches exciting new silicon for the next generation graphics platforms.
RESPONSIBILITIES
- Drive power technology and deliver power solution for silicon verifications, reference designs, custom OEM/ODM solutions for consumer, channel and workstation markets with optimum performance, cost and re-usability meeting TTM
o Review customer requirements and lead performance and cost comparative analysis
o Research and evaluate components, simulate circuits, schematic capture, generate BOMs and perform cost analysis to provide optimum solutions for volume production
o Work with board design engineers to plan board power budget and power distribution
o Work with thermal-mechanical team to overcome thermal challenges
o Guide and review power layout to ensure signal integrity and EMI performance with minimum layer-count and PCB real-estate
o Debug prototypes and sign-off hardware qualification reports
o Support production and resolve post-production technical issues
- Platform and system power development from silicon integration/feature requests to board/system architecture and industry specification definition and review
- Drive cross-functional teams to resolve issues
- Lead technical reviews with customers
- Participate in internal and external technical working groups or forums
REQUIREMENTS
- B.Sc. or M.Sc. in Electrical Engineering or equivalent focused in Power Electronics
- 4+ years of power design experience for microprocessors in motherboard or graphics board/module or equivalent
- In-depth theoretical and practical knowledge in microprocessor power requirements, component and PDN parasitics, controller topologies and algorithms, bandwidth and compensation design, large-transient response optimization, PSM, voltage/current sensing architecture, dynamic voltage managements, device integration, package thermal limitation, etc.
- In-depth knowledge of power electronics simulation tools (Pspice, Simplis, MATLAB, etc) and lab equipments
- In-depth knowledge of the latest component developments and trends related to VR designs
- Working experience with leading microprocessor power suppliers
- Proven ability to lead complex/fast-pace projects from specification through to production
- Knowledge of high-speed mix-signal multi-layer design techniques
- In-depth understanding of relevant industry standards: VR specifications, interface (PCI Express, MXM), ATX/SSI power supply, I2C, PMBus, DrMOS, Energy Star, etc
- Must be a self-motivated contributor and a strong team player with technical leadership skills to support optimal team performance
- Some level of technical leadership experience is desired
- Excellent team work, communication and organizational skills
https://amd.apply2jobs.com/index ... 0&CurrentPage=1
Title:                SMTS Electrical Analysis and Debug Engineer
JOB DESCRIPTION
Processor silicon DDR interface electrical test and debug engineer in the Shanghai Research & Development Design Center.  In this role, this senior level engineer will be part of a highly technical team that develops test plans, executes bring-up & test plans, & debugs electrical issues in the memory sub-system of new processors. The job entails extensive hands-on lab work as well as technical leadership and communication across teams.
1) Provides DDR technical leadership in the development of new test & validation features
2) Closely interacts with silicon design (DRAM controller and phy) in test execution & debug, as well as in feature definition for future product generation
3) Writes comprehensive electrical & functional test plans for the memory validation of processors
4) Executes electrical & functional test plans for AMD processors using hardware & software validation tools, oscilloscopes, & logic analyzers.
5) Debug of electrical & functional issues of the memory sub-system of new processors
6) Provides detailed input into the platform definition & review of platform designs used in the silicon validation of new processors.
7) Provides technical guidance and training to less experienced engineers and technicians in the planning, test, & debug of the memory sub-system.
SKILLS REQUIRED
1) BS-EE / BS-CE with at least 10 years directly related experience. An advanced degree will be considered a plus.
2) Requires experience and demonstrated technical expertise in the development & execution of platform level electrical & functional test plans. DDR2/3 Memory test experience on electronic components such as uProcessors would be considered a big plus.
3) Requires extensive hands-on experience and demonstrated technical expertise in the debug of I/O interfaces such as DDR
4) Demonstrated experience with or knowledge using oscilloscopes, reading schematics and layout documentation
6) Demonstrated ability to communicate with a variety of engineering disciplines and management.
https://amd.apply2jobs.com/index ... 3&CurrentPage=1
Title:                SMTS, Hardware Platform Design Engineer
DESCRIPTION OF POSITION:
Technical leader responsible for graphic, motherboard, and system design in our Shanghai Research and Development Center (SRDC). Systems are integrated combinations of hardware components (CPUs, graphics, memory, IO adapters, peripherals, and BMCs) and software components (firmware, drivers, OS, virtualization, and system management).  This individual will interface with the Marketing, Silicon design, Software, and Validation teams to define our platforms for new silicon, provide detailed technical direction to the SRDC engineers to draw schematics, layout the board, develop the System BOM, bring up, debug issues, and complete Motherboard QA testing.
•        Motherboard and system specification, negotiate features with input teams and silicon designers
•        Schematic capture and guide layout of motherboards for new silicon
•        Feedback and refine design rules with simulation and silicon design teams
•        Bring up and validate motherboard and systems
•        Negotiate solid solutions to technical issues and design challenges
•        Ensure all processes are met in development
•        Contribute to client system development processes, team development, tool development
•        Support silicon validation, characterization, and debug of existing and new microprocessor and chip-set products
•        Project planning, status tracking, and reporting to senior management
REQUIRED SKILLS:
•        Excellent communication skills
•        Prior experience with software testing tools and environments, defect tracking, and revision control
•        Familiar with Microsoft Client Operating Systems, Linux Operating Systems, virtualization software (VMware, Xen, et al), and validation/certification processes for each of these environments
•        Familiar with client system component compatibility and stress testing
•        Familiar with high performance client IO adapters, drivers, and stress testing
•        Familiar with general Computer Architecture concepts
•        Skilled in Cadence Concept schematic capture
PREFERRED SKILLS:
•        Familiar with Cadence Allegro layout tools
•        Familiar with MS Office & MS Project tool suites
•        Familiar with microprocessor bring-up and debug
•        Familiar with C/C++, JAVA, and scripting language programming
A Bachelor's and/or Master's degree in Computer Science or Computer Engineering. Requires 10-20 years experience leading computer system development.
https://amd.apply2jobs.com/index ... 5&CurrentPage=1
Build and provide technical leadership and direction to the system debug team. Systems debug team is responsible for analysis and resolution of AMD silicon and system issues which are on AMD reference platform designs and customer development stage PC systems across a broad range of market segments using oscilloscopes, logic analyzers and software/hardware debug tools in an intense but rewarding environment
This person is responsible for establishing and maintaining AMD’s technological leadership position in Systems Debug domain. The individual will be responsible for projects and processes of significant strategic or commercial importance and for project/program results. He/she needs to be able to strategize and provide long term planning in technical as well as managerial. This individual should be able to coach/mentor experienced staff and provide consultative direction to Senior management. The individual will pioneer hardware/software design improvements to internal and external designs and will provide solutions to external and internal customers. Define innovative test fixtures, experiments, diagnostics and analysis procedures as needed. The successful candidate must have an intimate knowledge of PC architecture and PC system busses and be a highly motivated, innovative individual with a keen interest in finding and resolving silicon and platform failures.
A technology related bachelor's degree or equivalent combination of training plus 9 years (or Masters with 7 years) lead-engineer experience in a computer system development and/or debug environment. Requires a good understanding of all PC HW and SW ( BIOS / Driver ) elements and knowledge of PC system architecture. Must be proficient in x86 32-bit protected mode assembly language. Requires effective communications and human relation skills. In depth experience w/ Hypertransport bus, DDR2 memory and/or PC I/O busses and the ability to rapidly learn new ones is preferred. Experience with micro-architecture and debug of AMD chipsets and/or CPUs would be a plus. Publications/patents in the system design/debug and participation in industry wide forums are preferred.
Title:                        Sr. Hardware Platform Design Engineer
1.Develops and reviews comprehensive specifications for board-level and system-level products, based on a clear understanding of the function to be demonstrated across design, testing, and use of the product
2.Designs board level products to meet the requirements of the project to agreed schedule, quality and cost requirements across the whole development lifecycle.
3.Focus on the electronic circuit design, test and debugging for the microprocessor based products such as PC desktop, mobile and server system.
4.Responsible for board/system level development including schematics design, components selection, system bring-up, tuning, and functional validation and debugging.
5.Feedback and refine design rules with simulation and silicon design teams
6.Negotiate solid solutions to technical issues and design challenges
7.Ensure all processes are met in development
8.Provides guidance for less experienced engineers
PREFERRED EXPERIENCE:
1. 5 + years experience in PC desktop, mobile or server system development or sustaining.
2. Strong hardware design skills as measured by successful delivery of digital designs.
3. Knowledge of design flow, product development processes, reliability verification, validation and compatibility testing.
4. Experience in Microprocessor based motherboard designs in the PC Desktop, Mobile and Server markets.
5. Familiar with PC, mobile or server architecture.
6. Proficient with the Windows Operating System.
7. Basic understanding of UNIX/Linux, software languages, and HDL sufficient to help debug system problems
8. Bachelor or above degree in an Engineering or Science area.
9. Ability to clearly communicate technical ideas across disciplines.
10. Proficient English and Mandarin (listening, writing and speaking).
11. Strong passion for achievement and career development.
12. Self-motivated and able to work independently and effectively to meet time requirements.
JOB TITLE:                 Sr. Electrical Analysis Engineer
JOB DESCRIPTION
Electrical test and debug engineer for CPU interfaces including DDR, Hypertransport, & Misc I/O in addition to functional validation & debug of CPU power management features.  In this role, the engineer will be part of a team that does the initial bring-up of new CPU’s & will work closely with the CPU validation teams plus platform design, silicon design, & BIOS teams to define the appropriate platform features & test plans for silicon validation. The engineer will also be very engaged in the debug of electrical & functional issues discovered as part of CPU validation, particularly in the areas for DDR & power management.
SKILLS REQUIRED
1) BS-EE / BS-CE and 3 years directly related experience. An advanced degree will be considered a plus.
2) Requires experience and demonstrated technical expertise in the development & execution of platform level electrical & functional test plans. DDR2/3 Memory, PCIx/PCIe or Hyper Transport Bus test experience on electronic components such as uProcessors would be considered a big plus.
4) Requires experience and demonstrated technical expertise in the debug of I/O interfaces such as DDR & Hyper Transport
5) Demonstrated experience with or knowledge using oscilloscopes, reading schematics and layout documentation, and MS Windows and Office applications.
6) Requires good written and oral communication skills.  Demonstrate the ability to communicate with a variety of engineering disciplines and management.
1) Executes electrical & functional test plans for AMD processors using hardware & software validation tools, oscilloscopes, & logic analyzers.
2) Use Oscilloscopes, Logic Analyzers and other tools to isolate and debug device and hardware problems in order to resolve internal release and complex customer related problems.
3) With limited direction, direct and define DDR Margining Test procedures on AMD Processors.
4) Writes comprehensive electrical & functional test plans for the validation of AMD processors
5) May review design specifications and manuals for AMD's system software and hardware based products with regards to their use within the testing infrastructure currently established or within future plans.
6) May lead or give direction and training to less experienced engineers and technicians.
7) Works on related projects or assignments as needed.
PROBLEM SOLVING/DECISION MAKING/ACCOUNTABILITY:
1) Exercises judgment within defined practices in selection of methods and techniques for obtaining results.
2) Expected to be complete tasks in a timely manner with thorough reporting of results verbally and/or written form
https://amd.apply2jobs.com/index ... 1&CurrentPage=1
Title:                        Lab & Inventory Specialist
Key Job Responsibilities:
-Responsible for the daily management of all Validation testing hardware and software receiving, check-in, location, check-out in a timely manner
-Maintain multiple inventory database systems/tools covering HW/SW and documentation
-Responsible for providing customized inventory status report and inventory space analysis
-Responsible for initiating and executing internal inventory item audit: monthly testing sample audit, quarterly testing sample audit, support yearly inventory audit
-Responsible for monitoring and driving semi-yearly inventory reclaiming process
-Work with global logistics team and onsite import/export agent to control inventory shipping inbound & outbound time/cost for validation labs
-Responsible for tracking Validation sample/equipment orders in specific systems with regular update to project management team
-Responsible for working with asset management team to locate and track Validation asset and providing status update
-Coordinate Validation engineering purchase request among GSM, Admin and Finance, execute payment request and track spending
-Responsible for maintaining a testing software server with updated drivers and documentation
-Responsible for duplicating and registering all testing software
Qualification
-Experience in IT industry inventory control with strong data tracking and reporting ability
-Computer software and tool manipulation: MS Office, Sharepoint, Visio, material logistics database
-Knowledge in statistics, asset management and material auditing
-High sense of IP protection and respect to R&D security
Preferred but not required
-Experience in engineering equipment and R&D sample import/export control
Title:                        Validation Engineer
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
-        Response to validate the system and silicon for internal design teams.
-        Perform the Software and Hardware level test using external and internal AMD test tools, including oscilloscope, analyzer, margin test tools, functional test…etc;
-        Analyze the failures found in testing and support the internal design team to find the root cause of the issues;
-        Assist validation team in improving the validation methods and procedures.
-        Bachelor degree of electrical engineering/computer science/computer engineering;
-        Good written and oral communication skills in both English and Chinese.
-        Self-motivated and able to work independently and effectively to meet time requirements.
-        Basic Experience with Networking and Mobile/Desktop/Server/Workstation.
-        Good knowledge of computer architecture and operating systems (Windows & Linux)
-        Linux Command Line Knowledge, knowledge of Windows.
-        Familiar with Oscilloscope and other electrical test tools
Title:                         Sr. Validation Engineer
• To verify and validate hardware products designed and developed in house at AMD using the standard qualification process and participates in creating/improving all phases of test procedures and methodologies.
• Participate in developing test strategies and Methodologies.
• Participate in defining, reviewing and improving test plans/procedures.
• Analyze the failures found in testing and support the internal design team to find the root cause of the issues;
• Assist validation team in improving the validation methods and procedures.
• Executing and/or automating the tests including some signal integrity analysis.
• Communicate with various internal departments to resole anomalies.
• Participate in issuing internal/external releasable test reports.
• Bachelor degree of electrical engineering/computer science/computer engineering;
• Good written and oral communication skills in both English and Chinese.
• Self-motivated and able to work independently and effectively to meet time requirements.
• Minimum 5 years of industrial experience in a hardware product testing or development environment
• Strong knowledge of computer architecture and all operating systems.
• Experienced in product development and sustaining process.
• Experience in system level hardware validation and automation software design.
• Linux Command Line Knowledge, knowledge of Windows.
• Familiar with Oscilloscope and other electrical test tools
•         To verify and validate hardware products designed and developed in house at AMD(ATI) using the standard qualification process developed within the hardware qualification group and participates in creating/improving all phases of test procedures and methodologies.
•         Minimum 3 years of industrial experience in a hardware product testing or development environment
•         Proficient in using electronic equipments such as digital oscilloscope, logic and network analyzer.
•         Proficient in using all MS operating systems and the configuration/setting of PCs.
•         Experienced in video/graphics product development and sustaining, system level hardware and software design
•        Solid background in IC technology
•         Experienced in board level design and development.
•        Familiarity with Linux is an asset.
Title:                        Sr. PCB Layout Engineer
Graphics Platform Engineering Team has immediate opening for a Sr. PCB layout engineer. Key responsibilities and requirements listed below
• AMD graphics and CPU MB PCB layout
• Customer support on PCB layout issues
• PCB layout new technology development
REQUIREMENTS
• Mandarin
• A minimum of 6+ years hands on experience for PC/server motherboard or graphics board PCB layout design(6+ years as a bachelor, 4+ years as a master)
Title:                 SOFTWARE SUPPORT ENGINEER – GRAPHIC DRIVER
Responsibility:
- Support customers to resolve OS/graphic driver related problems. Duplicate, isolate, and debug the reported graphic driver issues from customers.
- Work with graphic driver developers to resolve graphic driver issues.
- Build graphics driver based on requests from customers.
- Tracking issue status and communicating with customer.
- Provide design guides and necessary documents to ODMs and OEMs. Communicate critical design items and share design experience with ODMs/OEMs.
- Answer ODMs/OEMs questions on AMD graphics product.
- On-site support customers when necessary.
Requirement:
- BS or MS in Computer Science, Information Technology, or equivalent.
- Over 2 years (Engineer) / 6 years (Sr. Engineer) of driver coding experience in C/C++
- In-depth knowledge of Windows driver
- In-depth knowledge of Windows OS architecture
- In-depth knowledge of Linux OS is a plus
- Expertise in Windows debugging tools is a must
- Graphics driver related experience is highly preferred
- Assembly code programming experience is a plus
- Proficient English and Mandarin (listening, writing and speaking).
- Ability to work in a team environment
-Willingness to travel for on-site support if required
Title:                        Sr. Software QA Engineer
1.This person should be able to, with limited direction, test BIOS and chipset driver software for compliance to specification and overall quality.
2.Should be able to work with AMD's software design teams to help define new AMD products from a testability, support and customer viewpoint.
3.Should be able to review design specifications and manuals for AMD's system software based BIOS and driver products.
4.Should be able to write comprehensive test plans used to insure compliance to specification and that overall quality goals are achieved
5.Should be able to work with AMD customers/partners to define AMD's test procedures, while meeting customer’s requirements
6.Desire candidate would also have a moderate to high level of programming experience which can be leveraged for projects which have automated testing opportunities as well as knowledge in open source and embedded system technologies (a plus)
Basic Requirements:
1.BS or MS in CS, EE or other engineering major
2.5+ years software QA testing experience in the PC industry
3.Strong communication skills in both Chinese and English
Title:                        MTS Software Development Engineer
Responsibilities
-   Co-work with Toronto architect close to drive Linux Graphics Driver architecture, and keep it advanced in the industry
-        Key interface on technical to talk with other components
-        Influence/coach team members on their technical careers’ growth
-        Key technical contributor in the component
Skill/background requirement
-   6+ years development experience on C language for master degree, or 4+ years development experience on C language for PhD
-        6+ years Linux kernel development experience for master degree, or 6+ years Linux kernel development experience for PhD
-        4+ years Linux X.org/XServer development for master degree, or 4+ years Linux X.org/XServer development for PhD
-        Have graphics development experience is a plus
-        Familiar with PCI/PCIe/AGP protocol is a plus
-        Pass CET-8 is plus
Job Title:                 Graphics Project Manager
Job Description Summary:
• Provide professional, timely and responsive project management and engineering support for an assigned list of customer accounts.
• Ensures co-ordination of AE/GPM activities within their team to ensure rollout to customers of complete, accurate and timely AiB Deployment reference design information and updates via the AiB Resource Center.
• Develop customer project support schedules, milestones and deliverables. Translate customer requirements into specific tasks for different functional teams
• Assess priority and severity of customer issues. Collaborate with the Application Engineer (AE) and coordinates AMD functional engineering resources to close all technical issues ensuring a successful project launch on behalf of the customer,
• Acts as a first level escalation contact for OEM/AiB/ODM customer project issues (technical and logistics).
• Recommends and drives customer & internal process improvements within and outside the customer support services organization as a means to improve overall OEM/AiB/ODM customer satisfaction and loyalty to AMD.
• Develop and maintain close working relationship with customer development teams. Regularly visit customers to discuss project status and provide training.
Requirements:
• BS/MS in Electric/Electronic Engineering, Computer Engineering, or equivalent.
• 5+ years in PC/x86 or related industry. Minimum 3 years experience in project management or design, sustaining, applications engineering or equivalent role within the electronics industry.
• 2 years board design or design support experience is a plus
• 1 year in a direct customer facing role (preferably with OEM customers) is preferred.
• Knowledge of PC design flow, product development processes, reliability verification, validation and compatibility testing.
• Proficient in English and Mandarin (listening, writing and speaking).
• Must have strong negotiation skills to broker solutions that satisfy both the customer needs and look out for the interests of AMD.
• Able to work under pressure and multitask
• PMP certification or MBA is a plus.
Job Title:                 Application Engineer – Mobile Discrete Graphics
Job Description Summary (Optional):
We are looking for a strong Application Engineer in Mobile Discrete Graphics. This is a very exciting, customer focused role, responsible for technical issue debugging and the solution managing for success of launching AMD mobile graphics hardware/software on Customer’s Platform. This position offers a unique opportunity to work with major OEMs and ODMs on state-of-the-art systems in an extremely dynamic high technology environment.
Job Description:
• The candidate works with internal teams and ODM/OEM technical teams to debug and resolve customer reported technical issues found in customer designs using AMD mobile graphics products.
• Provide hardware and software technical guidance and information to AMD’s customers to support of their PC mobile graphics design projects;
• Perform PC schematic and PCB layout reviews
• Respond to ODM/OEM requests for factory on-site support
Requirements:
• A Bachelor’s and /or Master’s degree in Electrical/Electronics Engineering, Computer Engineering, or equivalent.
• 3+ years HW design and debug experience in Motherboard, notebook, or graphic card.
• Knowledge of notebook design flow, product development processes, reliability verification, validation and compatibility testing.
• Proficient English and Mandarin (listening, writing and speaking).
• A self-motivated individual who can work well with internal and external engineering experts to develop practical solutions timely to challenging technical problems
• Experience in Firmware BIOS/ Operating Systems (Windows, DOS, Linux) / Display driver interaction is a plus
• Know how to use Agilent or Tektronix machine for PCIE, HDMI and Display Port testing and debug is a plus
• Willingness to travel if required
发表于 2010-4-29 09:34:01 | 显示全部楼层
attracting ~~~~
发表于 2010-4-29 20:01:09 | 显示全部楼层
yes , it is atratciong so
 楼主| 发表于 2010-5-6 10:14:09 | 显示全部楼层
顶一下
发表于 2010-5-9 19:42:08 | 显示全部楼层
顶一下
发表于 2016-1-24 13:28:09 | 显示全部楼层
good info
GMT+8, 2025-12-21 06:07 , Processed in 0.024119 second(s), 6 queries , Gzip On, Redis On.
